Turbo b16 problems
Old Jul 15, 2004 | 08:38 PM
CRXB16PSI10's Avatar
Default Turbo b16 problems
I put a greddy turbo kit on my crx with a b16 swap. I'm having a problem once the car is started, it will idle find for the first few seconds them the rpms jump to around 4,000 rpms. I have RC 310 enjectors in right now but they are SATURATED which are for the newer model b series motors where an 88 crx with b16 swap come with PEAK AND HOLD injectors. If anyone knows why it reving so high please let me know.
thanks,
Daniel
Old Jul 15, 2004 | 08:46 PM
Nature's Renewal's Avatar
Default Re: Turbo b16 problems (CRXB16PSI10)
don't use the resistor box if that's the case; check for any vac leaks. Also, what engine management do you have? I'm guessing you have the blue box. The blue box was designed for stock injectors so why not use them now until you get some better management?
Old Jul 15, 2004 | 09:29 PM
Default Re: Turbo b16 problems (krskid)
so all i need to do is unplug the resistor box and the RC SATURATED injectors will work??? i didn't wire up the blue box because i figure with a fuel pressure regutator would be ok with the RC injectors
D-meet07
Aug 26, 2005 04:25 AM
88crxhfb16
Apr 6, 2005 01:23 PM
jdmacura
Oct 17, 2003 02:37 PM
crx1856
Aug 4, 2003 09:19 AM
