clicking noise
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorteg_96 »</TD></TR><TR><TD CLASS="quote">it could be your axles, or ball joints.</TD></TR></TABLE>
i'd have to say the same thing. most likely its your passenger side axle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supraznki »</TD></TR><TR><TD CLASS="quote">what can i do to fix this?</TD></TR></TABLE>
Get a new axle or ball joint.
its probably the cv joints. Check to see if ur cv boots have been torn. Usually it happens as a result of the cv boot being torn and the grease all fallin out and the joint is all dry and cracks.
I belive there are a few write ups on how to change a axle if u want to do it your self. https://honda-tech.com/zerothread?id=382416 .it is very simple. You can pick up a new axle a auto zone.
I agree, it is you're cv joint...you can take out your axle, and pull apart the rubber boot and all of its contents...then replace them with new components re grease them put on a new rubber boot, and band it....then install it.....or you can go to Autozone and get the same axle for your year/make/model, replace your "clicking" axle with it...and have a lifetime warrantee if it ever happens again..or (like what happens to me)..I break them racing. but dont tell Autozone that...shhhhhh.
drewhart
Apr 19, 2006 02:17 PM
D for D series
Jan 29, 2005 09:08 PM
rice_classic
Dec 11, 2004 05:15 AM
