engine rust
Old Jul 15, 2004 | 05:23 PM
kevinEGcivic's Avatar
Default engine rust
I have a 95 civic coupe. I noticed that my engine is quite rusty (engine mounts, bolts, brackets,etc.) is there any recommendations at how to clean this? please help me. i cleaned out my engine bay, but appearance wise , it is still ugly as hell. thank you.
Old Jul 15, 2004 | 05:26 PM
JimmyAtlantis's Avatar
Default Re: engine rust (iampaimei)
You could probably try some TC-11
Old Jul 15, 2004 | 05:33 PM
Master23's Avatar
I don't think you'll be able to remove rust from bolts or mounts. You might have to replace the bolts with new ones. For engine mounts you can just sand the rust off and spray paint it black for an OEM look.
Old Jul 15, 2004 | 05:36 PM
SolObsession's Avatar
Default Re: engine rust (Jgears)
Man I would love to go out in the garage one morning and just replace all the nuts/bolts, wire brush all the surface rust away and spray paint it.....man that would be fun but I doubt it will happen. But you gotta figure if someone does it to an old muscle car or street rod, why can't you do it to a Honda?
Old Jul 16, 2004 | 07:28 PM
i was thinking about replacing all the nuts and bolts... but where the hell am i going to get all that?
Old Jul 16, 2004 | 07:45 PM
StrikerX's Avatar
Default Re: (iampaimei)
dealer so that you get all the right sizes. might cost more but then again no reason to get from a pick a part since the bolts/nuts will also be rusted.
Old Jul 16, 2004 | 08:41 PM
Default Re: (StrikerX)
Take them off and spray them with a rattle can.
Old Jul 16, 2004 | 08:56 PM
dirtyturtle's Avatar
Default Re: (SolObsession)
i do exotic sports car restoration for a living. i do this **** everyday.
remove all the bolds you want cleaned. get them cadded(or chromed), and THICK paint(make sure you mask off the threads so it will still thread on)
just painting will not work for very long. the rust will eat it and it will continue to rust.. by cadding the pieces you stop the rust.
or if you wanna cheap out but still do a fairly respectable job.. a beat blaster is your best friend...
Old Jul 16, 2004 | 10:09 PM
stingray2772's Avatar
Default Re: (JDMPROject)
im going to get a cheapy rock tumbler and some metal media... let that go at it for a day or so, shines right up, and it doesnt mess up the threads, a friend and i did it to his old car
Old Jul 16, 2004 | 10:16 PM
Default Re: (stingray2772)
here are some examples of what im talking about, i found some tumblers at a yard sale today, my friend already had one though, in their catalog they have metal media for removing rust and stuff....
http://www.harborfreight.com/c...46376
http://www.harborfreight.com/c...46377
nvm, found the stuff here it is
Old Jul 16, 2004 | 10:21 PM
vtakk eg's Avatar
this rock tumbler theory sounds intresting
Old Jul 16, 2004 | 10:30 PM
Default Re: (EGmailman)
works pretty good, just dont forget you'll still gotta do a little work, but get a can of clear or your favorite color paint and spray em up, in case you need help, get a long magnent strip and hang it, put the bolts to it and it holds up fine while your painting.... works good for small things like all the little bolts, bigger things arent so easy, but they make larger size units specifically for doing this not from harbor freight though
Old Jul 17, 2004 | 06:23 AM
ive never done that (rock tumbler/metal media) . i will definitely try that out , just got to hook up with the right people down here. everyone here says i should just swap out the engine and save my self the headache. what do you guys think? maybe a B-series?
well that would be nice. but, ill see what i can do with my Sohc engine for now. thanks alot!
gsxr1k05
Sep 24, 2006 07:52 PM
Shake and Bake
Jul 23, 2006 12:23 PM
USDM EG
Welding / Fabrication
23
Feb 17, 2006 09:07 AM
