Honda S2000 Honda S2000
whining noise coming from rear???????
Old Jul 15, 2004 | 05:18 PM
s2kride's Avatar
Default whining noise coming from rear???????
i getting almost like a wind noise and a rubbing noise when i turn the wheel all the way to the left or the right i just changed the diff fluid does anyone experience this or know what it might be???? thank you
Old Jul 15, 2004 | 05:20 PM
DsITR's Avatar
Default Re: whining noise coming from rear??????? (s2kride)
are you on the OE wheels/tires and suspension?
I haven't noticed a whining in the S (I haven't driven it too often), But LSD in my ITR makes a slight whining noise.
Old Jul 15, 2004 | 05:22 PM
s2kride's Avatar
Default Re: whining noise coming from rear??????? (DsR)
yes new tires also aligned so i dont know what it could be u think it could be the rear brakes???
Old Jul 15, 2004 | 07:05 PM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kride &raquo;</TD></TR><TR><TD CLASS="quote">yes new tires also aligned so i dont know what it could be u think it could be the rear brakes???</TD></TR></TABLE>
That's a slight possibility. The squeelers (I don't know the technical term.) could be making noise, but it's usually very high-pitched. check out your pads and see how much is left.
One thing to consider though is your front pads usually do much more work, so they wear quicker. if you haven't replaced your fronts yet, it would be really odd to replace the rears.
Old Jul 18, 2004 | 10:13 AM
evil vapor's Avatar
is the noise speed dependent, meaning if you go faster, does the pitch of the increase as well as volume? At what speeds do you hear it? Any clunking noises? Specifically while turning one way as opposed to the other?
paxplace
Jan 26, 2012 09:38 AM
matix
Jun 28, 2006 03:18 PM
DeregginOut
Jul 4, 2002 11:40 AM
R249
Apr 28, 2002 04:58 PM
SpoonFed
Feb 26, 2002 01:41 PM
