New D-ninja turbo setup! SSAC = winnarr! 56k=die
D series Sol has a new turbo setup
jdm D15b Vtec w/ Uberdata P28
-Old setup was an HF manifold, T3 42 trim turbo w/ internal gate, and 2.5" downpipe to now sporting a SSAC manifold (Braced and supported!), T3 60 trim 60ar turbo, Tial 38mm external gate, 3" downpipe and 1.5" open dump tube.
I havn't gotten on it much (open DP is too loud!) but i can already tell its much faster then my old setup..
Any ways.. heres some pics..
Old setup:
New turbo and manifold:
1 of 3 SSAC support bracket/braces
New setup installed:
You can see one of the brackets installed here: (goes from bottom block bolt to the turbo flange)
The brackets I fabbed up came out really good.. They support 100% of the turbo/wastegate weight. I could take the manifold off and the turbo would be supported in midair
The WG dump tube and screen mesh filter are only temp.
Im going to have an exhaust shop redo the WB flex pipe with some nice piping and have them fab up a 2.5" S bend to put my HKS style filter up by my headlight.. Holla @ any questions & comments.
Old setup:
ur car looks pretty sick. I have a similar turbo but mine didn't come with the inlet pipe that bolts to the compressor side of the turbo. Where did u get urs from? I just have some screen mesh bolted up where the holes are right now.
b18c1wes
Jan 5, 2005 01:48 AM
