How To Adjust HIDs...
Old Jul 15, 2004 | 04:15 PM
civicHBphtride's Avatar
Default How To Adjust HIDs...
I Installed My HIDs and the left light is lower than the right.. How can i fix this problem so they'll both be at same height?
Old Jul 15, 2004 | 04:23 PM
ncsob16's Avatar
Default Re: How To Adjust HIDs... (civicHBphtride)
You have projectors or placing them into ur stock headlights??
Old Jul 15, 2004 | 04:36 PM
Default Re: How To Adjust HIDs... (ncsob16)
I have stock lamps..
Old Jul 15, 2004 | 04:37 PM
2000 lamps..
Old Jul 15, 2004 | 04:53 PM
Andres-eh2's Avatar
look for some type of screws behind the housing, its like a 10MM and just turn them until you see fit
Old Jul 15, 2004 | 05:28 PM
Ej1_coupe's Avatar
Default Re: (Andres-eh2)
Yup.. just adjusted mine 3 minutes ago.. pull up to garage or house, turn lights on and adjust the bolt behind the headlamp.
Old Jul 16, 2004 | 11:16 AM
Default Re: (Ej1_coupe)
hey can someone maybe show me a pic of what the screw or bolt looks like please..
Old Jul 16, 2004 | 11:43 AM
Andres-eh2's Avatar
just look behind your freakin' headlight
Old Jul 16, 2004 | 11:48 AM
6SPD_EK's Avatar
on my '00 hatch - you adjust with a phillips head screwdriver...you see the slots cut away where you slide the screwdriver down...& there is a round piece of metal with jagged edges...turn the screwdriver to rotate that...its easy...just go look behind you headlamps
BTW there are 2 of these per headlamp one adjusts horizontally & one for vertical adjustment
BTW its not TOO HARD to search...took 1 min... archive topics "adjust headlights" limited to eg+/del sol forum for people that can't search ...BTW you get different results when you search "adjust headlight" (no s)
(with pictures https://honda-tech.com/zerothread?id=799259)
Sp00nFed EM1
18
Mar 4, 2007 05:30 AM
J1A1H
Apr 10, 2006 10:24 AM
kikkoboyie
Feb 13, 2006 08:07 PM
S-Type1
11
Dec 2, 2004 07:18 PM
DIRep972
Nov 18, 2001 05:17 PM
