valve spring rmeoval
Old Jul 15, 2004 | 03:53 PM
importlegions's Avatar
Default valve spring rmeoval
how do i remove a valve spring without having to spend money on the vavle spring compressor tool, and how do u connect the retainer/take it off?
Old Jul 15, 2004 | 04:05 PM
Default Re: valve spring rmeoval (importlegions)
bump!@$!@$!$#$
Old Jul 15, 2004 | 04:43 PM
ryanstev's Avatar
I don't think you can.
The springs have to be compressed and it would be impossible to do by hand.
Old Jul 15, 2004 | 05:01 PM
ms1motorsports's Avatar
You can remove a valve spring by taking sprk plug socket and put it over the center of the retainer. Then take a hammer and hit the socket. This will dislodge the keepers and the retainer will come off. Just be sure to be careful when doing this as you don't want the spring to come back at you. You will need the honda tool to put the head back together though. There is no way around that.
Old Jul 15, 2004 | 05:14 PM
Default Re: valve spring rmeoval (ms1motorsports)
is that not going to damage the valve? will i be able to use that spring and retainer after hitting it?
Old Jul 15, 2004 | 07:02 PM
deSigi's Avatar
Yes, but the tricky part is putting them back in.
Old Jul 15, 2004 | 08:45 PM
Redline130's Avatar
A valve spring compressor is going to make the job much easier.
Here you go: http://www.thetoolwarehouse.net/shop/SP-91400.html
It's even on sale...very much worth it IMO.
Old Jul 15, 2004 | 08:53 PM
JL's Avatar
JL
Default Re: valve spring rmeoval (Redline130)
mother! that would have been so much easier! we used a socket to remove all the stock R retainers/springs from my friends type-r and then used a c-clamp and cut the side out of a socket to re-install the portflow springs/retainers.. it got the job done but was kindof sketchy! :D
JDM_SOHC
Mar 23, 2012 01:42 PM
Fezzie
12
Aug 21, 2006 12:49 PM
99EletronblueSI
Nov 8, 2004 08:24 PM
Screamer
Dec 17, 2003 04:41 PM
