need help removing a z6 intake manifold
yeah i have taken all but one bolt off the intake manifold, it's from a d16z6 and it's the middle bolt on the bottom. Does anyone have any tips for me? what did you guys use? i have tried for the last 2 hours on this one bolt......how sad
you need a joint on the end of your ratchet. Also did you get the two that are under the manifold. they are on a support brace thing.
I always reach under the right side of the manifold with a small craftsman 1/4" drive w/ the short 10mm, once you break it loose you can normally undo it by hand. either way that nut is a pain in the ***.
I got mine from under the car. I already had the car jacked up to get the pesky lil bolts in the brace so I just reached up there and snagged the one on the bottom of the manifold. dang those Japanese and their tiny hands!
