14b turbo on 2nd Gen ZC... what are the best plugs, wires and ECU?
Old Jul 15, 2004 | 03:22 PM
Sweet_PSI's Avatar
Default 14b turbo on 2nd Gen ZC... what are the best plugs, wires and ECU?
ok.. so i had a 93 si vtec turbocharged on 6 psi... then i popped the thing.
now i bought a 2nd gen ZC DOHC, non-vtec, 1.6...
now... of course being non-vtec, the stock ECU from the SI will not work unless its chipped...
i was wndrering whether there's an easier way. DOES NE ONE KNOW OF A ECU THAT'LL RUN GREAT WITH THIS SET-UP??
my next question is i need colder plugs... which ones are best...
and what spark plug wires should i use??
Old Jul 15, 2004 | 03:30 PM
86si's Avatar
Default Re: 14b turbo on 2nd Gen ZC... what are the best plugs, wires and ECU? (Sweet_PSI)
NGK bkr7e,88 integra factory honda wires work best,and as far as an ecu a 94-95 integra ecu will plug right in and probably work well.
ek_99_SiR's Avatar
Default Re: 14b turbo on 2nd Gen ZC... what are the best plugs, wires and ECU? (86si)
for an ecu go , pm6
Old Jul 15, 2004 | 03:38 PM
86si's Avatar
Default Re: 14b turbo on 2nd Gen ZC... what are the best plugs, wires and ECU? (1.6i-16zc)
pm6 is 88-91,he has a 93 civic
Old Jul 15, 2004 | 04:39 PM
Sweet_PSI's Avatar
lol.. actually im a chick... lol...
ok so this motor is an obd1, is a pm6 plug n play with that... or is it for a obd0??
Tippyman
May 13, 2007 02:02 AM
D-Boi901
Jan 9, 2007 08:33 PM
Tippyman
15
Mar 28, 2006 10:18 AM
