Can I Swap in Cruise Control from an EX Sedan?
i'm pretty sure it's possible..i wanted to try it since i drive long trips several times a year, but i never got around to it, jdm and other stuff held me from doin that
Yes.
You need the CC pedal assembly.
The CC 'brain'...mounted on the heater box, to the right of the accelerator pedal.
You need the steering wheel...or at least the two switches from it.
The actual Cruise Control switch that's on the sedan dashboard.
You need the Sedan gauge cluster, or at least the cruise control section....which can be retrofitted into the hatch/CRX gauge cluster housing.
You need the underhood cruise control box and the cable which goes from the box to the throttle body.
And then you get to have fun wiring it all up!
MrToasty
Aug 30, 2013 01:18 AM
stackz
Jan 17, 2007 03:31 PM
