spark plug problem...
Old Jul 15, 2004 | 01:32 PM
pootie.teng's Avatar
Default spark plug problem...
hey i've been spending a lot money on spark plugs and here is my problem.
the spark plug keeps on breaking lose in the middle, ceramic area. when i pull the plug the whole middle inside part of the plug is lose and i can move it up and down and i can twist it around. anyone know why this is happening.
Old Jul 15, 2004 | 01:41 PM
Rocket's Avatar
Default Re: spark plug problem... (teckno_geek)
It's just loose but pieces of it are not breaking off?
Old Jul 15, 2004 | 01:46 PM
Rtype16's Avatar
Default Re: spark plug problem... (Rocket)
Youa re tightening the spark plugs too much. That is why they are breaking there.
Old Jul 15, 2004 | 01:52 PM
nope nothing is breaking off. just the whole electrode and ceramic part gets loose from the thread. you can move it around. everytime the cylinder comes to the compression stroke you can hear the plug go up and down like the valves was loose
Old Jul 15, 2004 | 01:56 PM
Rocket's Avatar
What's the brand and part number of the plugs?
Old Jul 15, 2004 | 01:59 PM
they just some bosch platnum 4's. cause eversince this happened i didn't want to get no ngk's for this to happen to it.
my setup is an built ls/vtec
Old Jul 15, 2004 | 02:07 PM
Rocket's Avatar
I like Autolite 3923 or NGK BKR7 for this app.
Old Jul 19, 2004 | 01:47 PM
Rtype16's Avatar
Yes as I said you are breaking the lower portion of the ceramic. This is due to overtightening the spark plugs.
Old Jul 19, 2004 | 02:13 PM
PreStaged12s's Avatar
Default Re: spark plug problem... (Rtype16)
Buy new plugs, coat the threads with some Anti-Seize, plugs should be torqued to 10-15 ft lbs, NGKs are the best plug for Honda in my opinion, unless your running something crazy with a rev limiter of 9500+ in that case I would say Denso Iridiums would be nice.
Old Jul 19, 2004 | 06:40 PM
-faded-'s Avatar
Default Re: spark plug problem... (PreStaged12s)
i use ngk bkr7e-11's in my NA built ls/vtec. great plug and not too expensive
Old Jul 28, 2004 | 06:30 AM
sil's Avatar
sil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreStaged12s &raquo;</TD></TR><TR><TD CLASS="quote">Buy new plugs, coat the threads with some Anti-Seize, plugs should be torqued to 10-15 ft lbs</TD></TR></TABLE>
I have a question about torqueing with anti-seize.. i put anti-seize on my plug and put a torque wrench to it set to about 11ft.lbs... i tighten it finger tight first and then put the torque wrench to it.. i've turned it quite a bit and it doens't seem to want to 'torque'.. soon after I decided I could be tightening it too much and so I stopped.. put a regular ratchet on and the plugs feel snug though.. is it possible that with the anti-seize torque setting will never be reached before you actually start stripping thing?
imzjustplayin
Dec 22, 2008 01:01 PM
RACEPAK
Sep 21, 2005 04:08 AM
Killashahmafia
Sep 14, 2003 02:02 PM
nek0
Jun 8, 2003 11:15 AM
