my radiator fan doesnt work.. i think...
Old Jul 15, 2004 | 01:02 PM
ironchef25's Avatar
Default my radiator fan doesnt work.. i think...
im not overheating or anything. but everytime i drive my car . i dont sense or hear my radiator fan spinning.. even after a long drive(25 miles) and then open the hood my fan still just sit there..the funny thing is that im not experiencing any overheating problem... another crx mystery... hmmmmm
Old Jul 15, 2004 | 01:03 PM
crx_88_si's Avatar
Default Re: my radiator fan doesnt work.. i think... (ironchef25)
it will usually only come on when idling. Driving makes wind go thru the rad and keeps the motor cool enough.
Old Jul 15, 2004 | 05:49 PM
kannon's Avatar
Mine runs all the time.... i think a relay may have gone, but im not sure which one.
Old Jul 15, 2004 | 06:30 PM
4DRmafia's Avatar
it must be a relay
Old Jul 15, 2004 | 06:31 PM
hatchinprogress's Avatar
Default Re: my radiator fan doesnt work.. i think... (kannon)
iron does it heat up in stand still traffic? my fan wouldnt turn on and i started to overheat, so for now i got my rad. and ac fan to turn on whenever i start the car!
Old Jul 15, 2004 | 09:03 PM
ironchef25's Avatar
Default Re: my radiator fan doesnt work.. i think... (hatchinprogress)
havent overheated yet.. but im kinna worried..
Old Jul 15, 2004 | 09:47 PM
SECURITY's Avatar
Mine's doing the same exac thing right now. I let it idle for a goot 20 minutes before I got scared and the fan never turned on. BUT the temp guage seems fine!! I'm going to tackle it in my spare time whenever I finally get a chance. If you figure it out let us know
Old Jul 15, 2004 | 10:27 PM
4DRmafia's Avatar
it the relay it happen to me once
Old Jul 15, 2004 | 10:57 PM
spaceman's Avatar
Default Re: (SkipMic2006)
i got the same thing going on too...what relay are you talkin about?
Old Jul 15, 2004 | 11:38 PM
4DRmafia's Avatar
the relay for the fan top come on when it reach the temp of the engine to cool down and the relay is really near the stock air box and near the headlight too , it a rubber boot coverd relay u should find it
Old Jul 16, 2004 | 05:14 AM
crx_88_si's Avatar
Old Jul 16, 2004 | 06:02 AM
ironchef25's Avatar
Default Re: (crx_88_si)
so what do i do with the relay???
Old Jul 16, 2004 | 06:11 AM
crx_88_si's Avatar
oops thats the wrong image..
do you have a helms? or similar?
Old Jul 16, 2004 | 06:53 AM
slowpokesi's Avatar
Default Re: my radiator fan doesnt work.. i think... (oh_crx)
check the fuses also, there is a radiator fan fuse, one under the hood and one under the dash
Old Jul 16, 2004 | 08:49 AM
hahagasdcrx's Avatar
Default Re: my radiator fan doesnt work.. i think... (slowpokesi)
Since noone has said it yet check your thermoswitch also. Best way to check if the fan comes on is to start the car and let it sit there at idle. Wait a few minutes and see if it comes on ( 5-7 minutes usually). If it doenst come on, and your coolant temp is getting high, check on the relays and the thermoswitch.
Old Jul 16, 2004 | 11:31 AM
crx2fast's Avatar
Default Re: my radiator fan doesnt work.. i think... (hahagasdcrx)
i have the same problem. the question is, how do you check the relay to see if its no good? and if it is no good, what do i do?
Old Jul 16, 2004 | 12:24 PM
4drEF's Avatar
Keyboard Humorist
Default Re: my radiator fan doesnt work.. i think... (crx2fast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2fast &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem. the question is, how do you check the relay to see if its no good? and if it is no good, what do i do?</TD></TR></TABLE>
You can troubleshoot it by following the Helms.
Check fuses first... make SURE that's not the problem.
You might find it easier to just test the fan and the thermo switch before checking the relay.
I would start with the thermo switch since it is such a common item to go bad.
Diconnect it and put a jumper (paperclip) in the plug and short the 2 wires together.
Start the car.
The fan should be on.
If so, then the thermo switch is bad.
If the fan didn't come on, turn off the car and reattach the wires to the thermo switch.
Disconnect the fan plug.
Run some jmper wires from the battery directly to the fan. It won't matter which wire goes where- the fan will either spin forward or on reverse.
If the fan doesn't spin then get a new fan motor.
If it did spin, then remove the jumper wires and reconnect the fan plug.
Trouble shoot relay.
Old Jul 16, 2004 | 12:29 PM
crx2fast's Avatar
Default Re: my radiator fan doesnt work.. i think... (4drEF)
thanks alot for the help ill give it a try
Old Jul 16, 2004 | 03:14 PM
spaceman's Avatar
anyone know if there is a way to check that fan relay to see if its working?..my haynes has no info on it
Old Jul 16, 2004 | 03:21 PM
beavis's Avatar
maybe your thermostat or thermostat switch for the fan is bad
Old Jul 16, 2004 | 03:51 PM
crx378's Avatar
I dont have a\c in my car, but i kept the fan, so i just ran a switch inside. that way when the temp gets higher than i like (like sitting in line at the track) i can just flip the switch.
Old Jul 28, 2004 | 08:26 AM
dntreid's Avatar
I'm having this problem too. Never had a problem with my 1997 Honda Civic LX until last week when temps reached over 100 degrees. Car started overheating while stuck in traffic. Turned off AC and ran heater which cooled it down. Once traffic picked up, could turn on AC without problem. Checked and noticed Radiator fan isn't coming on. AC compressor fan works OK. Pulled off plug from cooling fan switch and jumped with paper clip. Turned on key and radiator fan came on without a problem. Figured the switch must be bad then. Replaced switch. Still won't come on. Started car while cold with radiator cap off, let heat up, and once it got warm, could see coolant start to circulate, and upper and lower hoses got warm, so I doubt it is a problem with my thermostat or water pump. As a last ditch resort, tested my old switch by hooking up an ohm meter to the switch while sitting it in a pot of boiling coolant on my coleman stove, once it reached approx. 228 degrees, the ohm meter changed from 1 to hovering around 50 ... don't know that much about ohm meters, but the fact that it changed from 1 at around the temp it was supposed to start changing, makes me think the original switch was never bad to begin with. Also checked all fuses. I'm at a loss as to what could be causing my problem. Car only has 72,000 miles on it and is in great condition otherwise. No problems, well maintained, just recently had 60,000 mile service with full cooling system service.
Any ideas on where to turn next? I'm a novice at this, so please ... don't assume I know anything. Thanks.
Old Jul 28, 2004 | 08:32 AM
slowpokesi's Avatar
Default Re: my radiator fan doesnt work.. i think... (dntreid)
check the relay's
did you check fuses under the dash and the hood?
Old Jul 28, 2004 | 08:36 AM
dntreid's Avatar
I checked both the fuse under the dash and the hood, both OK. As for the relay, I figured that by jumping the cooling fan switch, that would trigger the relay, and since the fan came on, the relay must have been good. Other than that, I don't know how to check the relay other than to just buy a new one and see if that works. Is my understanding wrong? Is there a good was to test the relay other than to just replace it?
Old Jul 28, 2004 | 08:40 AM
Driven's Avatar
if you have a DX or HF, get a turn signal stalk from a SI.
wire up the fan to the REAR WIPER switch on the stalk. you can turn it on/off whenever you'd like.
