Is the TPS plug the same on all 96-00 Civics?
Old Jul 15, 2004 | 12:14 PM
kannon's Avatar
Default Is the TPS plug the same on all 96-00 Civics?
I need to know if the TPS plug on the wiring harness is the same on a 99-00 Si as on other Civics from that generation?
As part of a JRSC installation from several years ago, I tapped into one of the wires with a scotch-lock connector. After years of moisture exposure and a functional hood scoop (functioning to dump water on my electronics), the wire corroded. I notices fluctuating values coming from the TPS, when i went to investigate, the wire snapped where it entered the plug.
I've pretty well butchered the plug trying to disassemble it, and my cat took off with the o-ring. I'd like to replace it, but I'm having a hell of a time finding someone to sell me a plug off of a harness. I prefer not to have to buy a harness and cut it (the horror!)
Does anyone know if I can use a plug from any 96-00 civic harness? If so, where would be the best place to get one? I posted a WTB in the classifieds, but no results yet.
THanks!
Old Jul 15, 2004 | 12:48 PM
nsxmatt's Avatar
Yep, should all be the same. Plug from the MAP is also the same plug.
sonic47
13
Feb 10, 2010 03:23 AM
ninty1civic
Nov 11, 2009 11:33 PM
jsnm
Jul 22, 2006 06:07 AM
tommiboy
Nov 9, 2005 01:21 AM
Jonathan_ED3
Jun 21, 2003 04:16 PM
