Remiving from rotors 96 honda accord
Old Jul 15, 2004 | 11:40 AM
TURBO's Avatar
Default Removing from rotors 96 honda accord?
Im having a bitch of a time trying to remove them I took the four bolts on the hub and the axle hub. How am I suppose to remove the rotor?
Old Jul 15, 2004 | 12:05 PM
91exaccord's Avatar
Default Re: Removing from rotors 96 honda accord? (TURBO)
You don't have to remove the four bolts at all. First take out the cv axle. Then if you have access to a hub shark tool press the bearing out and the rotor will come with it. OR you have to use a slide hammer and beat it out, which in either case usually ruins the bearing. The rotor wont just come off because it is trapped on the car by the bearing. Then once the bearing is out you remove the four bolts to release the rotor from the bearing hub.
Old Jul 15, 2004 | 12:26 PM
TURBO's Avatar
Default Re: Removing from rotors 96 honda accord? (91exaccord)
So hit the back of the hub to push it out? any other way to do it without ruining the bearing?
bryan0
Mar 25, 2014 10:57 PM
Kyoto now
Mar 21, 2007 07:15 AM
conker
Oct 1, 2006 04:10 AM
haashaus
Dec 14, 2005 07:22 AM
BigLoadChoakHard
Jun 22, 2003 06:41 AM
