98 gsr trans mount...
i got a 98 gsr motor in a 95 hatch
im on hasport.com and i see the mounts i need... obviously i need the hydro trans 1.. BUT do i get the left or the right side... the left looks like the driver side mount... and the new 1, the manual trand mount for auto i dont need considering my car was manual to start off with.. i dunno, i just need to be sure!
The kit that you would need appears to be this one.
EGSTK
But if you're talking about the upper tranny mount, I was under the impression that you could use your original set.
Can anyone confirm for him?
EGSTK
NO aftermarket mounts/brackets are needed for a B series hydro swap into an EG. As long as you are using a B series hydro tranny (94+ Integra's are all hydro) then you can reuse the stock D series upper tranny mount or the 94-01 Integra upper tranny mount.
i have all the stock mounts - BUT the motor moves around to much, i have the rear mount, now i would like more stiffness upfront, so i figure id go ahead & purchase the trans mount 1 now and then later on, pick up the d/side mount
Razr2
18
Mar 15, 2008 08:59 PM
Si Integra
Mar 9, 2005 12:38 PM
