Piston surface....
Old Jul 15, 2004 | 06:16 AM
menkio's Avatar
Default Piston surface....
i was wondering about the diffrence from your typical casted piston surface, and the forged polished surface of a piston. I would image the polished, ultra smooth surface would help control detonation.. but what else.. better blast.. what....
Old Jul 16, 2004 | 12:34 AM
menkio's Avatar
Default Re: Piston surface.... (DewMota)
Old Jul 16, 2004 | 02:34 AM
menkio's Avatar
i'll post a picture, maybe that will help.
Old Jul 16, 2004 | 02:57 AM
KingDsi's Avatar
I am no piston guru, but from what I read, the top of the piston should be as smooth as possible. It should be free of burrs, and any sharp edges should be sanded down. Also, I read that polishing the tops of the piston helps. Anything to keep hot spots down (sanding sharp edges) and keep carbon and other risiduals from bonding to the piston top (polishing), helps to prevent detonation.
Old Jul 16, 2004 | 02:59 AM
KingDsi's Avatar
Default Re: Piston surface.... (KingDsi)
Even some new forged pistons can go through the sanding and polishing
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
viera
Jan 16, 2010 10:29 PM
Sliced Beard
Jan 22, 2004 06:55 PM
eghonda
Nov 10, 2003 09:19 PM
98Psi ITR
Jan 26, 2002 08:52 PM
