Dome Light / Map Light Does Not Work
Old Jul 15, 2004 | 05:28 AM
ironlung78's Avatar
Default Dome Light / Map Light Does Not Work
I pulled out the back seat and all the interior plastics out of my 00 Si so i could replace the rear speakers and wire up my amplifier. At the same time I pulled out the headliner so I could steam clean it because it was dirty. Now with everything pulled out my maplight and Dome light don't work. It looked like the fixture for both lights actually grounded the light. So instead of leaving them hanging i screwed them back up there to ground them. I checked all the connections and fuses and all were good. Everything else in the car works except for the bell to let you know that the lights are on. Does anyone know why they might not work??? Suggestions?????
Old Jul 15, 2004 | 07:07 AM
skrewdriver88's Avatar
Default Re: Dome Light / Map Light Does Not Work (sidesi)
I have same problem, the only time it works is when i push the botton to on but i doesn't work for my doors open sensor
Old Jul 15, 2004 | 07:16 AM
Ej1_coupe's Avatar
Default Re: Dome Light / Map Light Does Not Work (skrewdriver88)
Did the light bulb burn out?
Old Jul 15, 2004 | 07:48 AM
jbs's Avatar
jbs
Same happened to me when I replaced my headliner. First I thought it was a burnt bulb but it still did not work after I replaced it. In my case it turned out to be a burnt fuse.
Old Jul 15, 2004 | 01:49 PM
nighttrain33's Avatar
If you replaced your stock stereo with aftermarket, then your dome light will not work when the doors are open. The factory alarm/keyless entry won't work either. This happened to me as well. Let us know how it turns out!
Old Jul 26, 2004 | 05:19 AM
HondasGalore's Avatar
Default Re: Dome Light / Map Light Does Not Work (nighttrain33)
Same thing happened with me. I found an alleged solution at <http://www.streetdreams.com/tech/hon...c9698.html>. I haven't tried it yet, but plan to and will report back when I have.
Schott24
Jul 14, 2018 08:13 PM
ftrms
Dec 2, 2009 11:40 AM
ahhsimon
Lighting
Nov 2, 2007 09:13 PM
kevinm1981
Mar 6, 2004 12:19 AM
