omni power (omni man) VS. RM(ef-1)
Old Jul 15, 2004 | 03:46 AM
JBBNJ609's Avatar
Default omni power (omni man) VS. RM(ef-1)
ok so im either looking at omni valves, springs, and retainers
or ef-1 valves,springs and retainers
they are with-in 15-20$ of eat other, im lookin at flat faced valves
they both look great, ive heard great things about both. im torn i dont know who to go with, they both offer great service as well( great guys, omniman and rocket )
Old Jul 16, 2004 | 05:19 AM
JBBNJ609's Avatar
Default Re: omni power (jason bouchard)
bump
Old Jul 16, 2004 | 05:26 AM
eRACING's Avatar
don't think you can go wrong with either of the two
Old Jul 16, 2004 | 05:33 AM
JBBNJ609's Avatar
Default Re: omni power (erics99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erics99si &raquo;</TD></TR><TR><TD CLASS="quote">don't think you can go wrong with either of the two</TD></TR></TABLE>
yea i feel the same way but im torn .. i want like of opinions . . and i want to hear from soem people who have or are running the setup as well
Old Jul 16, 2004 | 06:32 AM
HYBRID_H@TCH's Avatar
I run all the RM (ef-1) valve train with great results (10.8 @ 132 turbo) and have never had one problem at all..but I also have a buddys engine built up with all of omni's valve train and have had zero problems and great results aswell..I say go with the better price or flip a coin..LOL
Old Jul 16, 2004 | 07:10 AM
TEAM562racing's Avatar
They are all pretty much the same thing
Old Jul 16, 2004 | 07:28 AM
fastdar80's Avatar
where can i look at your valvetrain and how can i purchase?
Old Jul 16, 2004 | 08:07 AM
RenoRacing's Avatar
Default Re: omni power (fastdar80)
I've ran the EF-1/RM valvesprings and retainers and had good luck with them. Great price and very nice product! They were by far the stiffest spring that I've ever felt(compared to skunk2, crower, itr). Which I've heard omniman say isn't always neccessary but reassuring none the less.... With that being said, next time round I might give omniman a try!
Either way you're dealing with and supporting two great guys who do more than their part in our scene!
Rocket
http://m24x.zeroforum.com/zeromain/
Omniman
http://omnipowerusa.com/
Old Jul 16, 2004 | 08:12 AM
X-cement-filled-EG-X's Avatar
* B A N N E D *
Default Re: omni power (RenoRacing)
im getting my head done by portflow with the omnipower full setup. the flat tops valves should give you a great bump in compression as well. .4 actually is the quoted #. check it out. go with what you feel comfortable with. i have faith in steve and know his products are worth whatever cost.
X-eric-X
Old Jul 16, 2004 | 12:31 PM
Rick Solis's Avatar
Just by looking st both Omni Power and RM, looks as if the valves/valve springs might be either the same or from the same source... The retainers are slightly different between the 2 though...
If thats the case, it wouldnt matter which one I guess...
I could be wrong though, Im just going by looks and aplications listings...
Rocket or Omniman chime in and correct me if Im wrong/off...
Old Jul 16, 2004 | 03:33 PM
zad5's Avatar
teh rm valvesprign i think are much more stiffer. made for more hardcore cams. but too much pressure mite not be good it could mess up the cam but i dont want to give false info. the omni power valvespring put out less pressure it seems that its made more for not so hardcore of a cam but im not sure. as for the valves im not sure which ones are lighter but their both flat faced.
Old Jul 16, 2004 | 03:38 PM
Rocket's Avatar
Default Re: (zad5)
Omni valvetrain or RM Gen2 for street!
Your choice.
Thanks very much for your interest Jason.
Old Jul 17, 2004 | 11:18 AM
Rick Solis's Avatar
Default Re: (Rocket)
Here are some of the reasons I think they may be the same products sold by both RM and Omnipower...
Valve springs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.m24x.com &raquo;</TD></TR><TR><TD CLASS="quote">
GEN-2 springs have 55 lbs. on the seat and 180 lbs. at 12mm of lift. These springs can handle up to 14mm of lift</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.OmnipowerUSA.com &raquo;</TD></TR><TR><TD CLASS="quote">
-Omni-Power valve spring measurements:
-Seat pressure 55 lb’s
-Coil bind 14 mm
-Pressure @ 12.7mm/.500 lift 180 approx. +-1%
-Max lift 13.2 mm</TD></TR></TABLE>
They use different retainers which would explain the differences in max lift lift... Rockets retainers are shorter, similar to JG's retainers which have been advertized as adding somewhere around .060 lift capacity... Omni's retainers are more of the portflow style...
Valves
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.m24x.com &raquo;</TD></TR><TR><TD CLASS="quote">Intake valves have the same underhead as the Type-R and a stemmed down neck to increase flow.It also has a thinner margin to increase valve to valve clearance and reduce weight. Exhaust valves are two piece and utilize an inconel head which can withstand extremely high temperature. All valve stems use the same metal as the OEM valves which prevent the tips from mushrooming. Special introductory price for complete set of intake and exhaust valves</TD></TR></TABLE>
Omni-Power B Series intake valves feature SUH-11 material which is the same material used by Honda. The tips are designed to prevent mushrooming and the stems are cut for increased flow and reduced weight (Just like Type R).
Omni-Power B Series exhaust valves are a 2 piece design just like OEM Honda. The upper stems are made out of SUH-11 and the heads are made out of NCF-751 (Inconel) to withstand extreme temperatures.
Our focus was to manufacture a product that not only performed well but could rival the reliability found in OEM Honda products. We feel that we achieved our goal and according to Brad at RLZ Engineering, these valves flow better than all other high end valves he has tested</TD></TR></TABLE>
That reminded me of this test...
http://m24x.zeroforum.com/zerothread?id=736
Just a few things I noticed... It looks, jusdging by the differences in retail pricing that Rocket is buying from Omni at wholesale...
But like I said, I could be totally off, just some coincidences I noticed...
Old Jul 17, 2004 | 06:13 PM
H25's Avatar
H25
We use omnipower valve train in all our customers cars now. inlcuding our pro am all motor car. Go with the best forget the rest!
Old Jul 17, 2004 | 06:21 PM
RABHonda's Avatar
Default Re: omni power (MHRacing-310)
flat face valves add weight, which in turn will increase possibility of valve float at higher rpms, and also more drag on the valve train itself. and for what? .2 points of compression? not worth it.
Old Jul 17, 2004 | 08:21 PM
itralex's Avatar
Default Re: omni power (RABHonda)
I'm running on Complete Rocket Motorsport (EF-1) Valvetrain
Springs, Retainers, and Valves, in my ITR
the only complain is that they run extra loud
Old Jul 18, 2004 | 11:23 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RABHonda &raquo;</TD></TR><TR><TD CLASS="quote">flat face valves add weight, which in turn will increase possibility of valve float at higher rpms, and also more drag on the valve train itself. and for what? .2 points of compression? not worth it.</TD></TR></TABLE>
.4 actually.....
X-eric-X
Old Jul 19, 2004 | 07:29 PM
98itR484's Avatar
Default Re: omni power (X-cement-filled-EG-X)
Both Robert (Rocket) and Steve (omniman) are great people, and are offering outstanding services and products to us at unbelieveable prices.
choose which ever one you personally like, I went with the complete RM line up.
However I will be using Omnimans race suspension when it is available.
Modified by 98itR484 at 12:26 AM 7/20/2004
Old Jul 19, 2004 | 11:56 PM
rusted_eyes's Avatar
RM is what I got and I wouldn't get anything different!
Old Jul 21, 2004 | 03:58 PM
myke's Avatar
From: South LA...107th and fig to be exact...for the foo
i've been running flat valves since they came out like two years ago and i havent had a problem with them yet...i use skunk stg 3 cams and its a daily driven car
Old Jul 21, 2004 | 04:27 PM
BluePrintmfg.com's Avatar
Banned
Default Re: omni power (myke)
omni power products good product at a good price, Steve really knows what he is doing BTW Steve I guess I didn't make enough at the street races @ Ontario that nite to cover the price for the broken hatch glass HAHAHAHHAHAH
Old Jul 22, 2004 | 02:42 AM
Default Re: omni power (11sec.ALL MOTOR)
omni products are badass..I have a full set of coil overs coming for my ride..nothing but the best..omni and RM
Old Jul 22, 2004 | 08:24 AM
Rick Solis's Avatar
Default Re: omni power (99Hybrid_Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">omni products are badass..I have a full set of coil overs coming for my ride..nothing but the best..omni and RM </TD></TR></TABLE>
As soon as the prelude CO's are ready Ill have a set
Old Jul 22, 2004 | 10:34 AM
xJ.SLOTHx's Avatar
O M N I
Old Jul 22, 2004 | 10:38 AM
WAFFLES's Avatar
Default Re: (Rick Solis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick Solis &raquo;</TD></TR><TR><TD CLASS="quote">
Or the opposite could be true, but we would have to hear that from the horsies' mouthes.
