removal of stock rods from pistons
Old Jul 15, 2004 | 03:22 AM
tegasaurus's Avatar
Default removal of stock rods from pistons
does a machine shop have to press out the pins that connect the rods to the pistons or is something terrrrribly seized up w/ my pistons/rods?
i have a new set of pr3 pistons and wrist pins and the pins just slide in and out freely - i don't get it?
Old Jul 15, 2004 | 03:51 AM
getgot22's Avatar
Default Re: removal of stock rods from pistons (tegasaurus)
Yes the wrist pins have to be heated and pressed out by a machine shop, and usuallty the old pistons will get damaged.
Old Jul 15, 2004 | 12:02 PM
tegasaurus's Avatar
Default Re: removal of stock rods from pistons (getgot22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by getgot22 &raquo;</TD></TR><TR><TD CLASS="quote">Yes the wrist pins have to be heated and pressed out by a machine shop, and usuallty the old pistons will get damaged.</TD></TR></TABLE>
anyone know how the new pistons attach to the rods considering the pins just slide around?
Old Jul 15, 2004 | 12:20 PM
Rocket's Avatar
The small end of the rod is heated so there is enough clearance for the pin to be pushed in. When the rod cools the clearance is gone and has a press fit to the pin.
Old Jul 15, 2004 | 01:05 PM
tegasaurus's Avatar
Default Re: removal of stock rods from pistons (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">The small end of the rod is heated so there is enough clearance for the pin to be pushed in. When the rod cools the clearance is gone and has a press fit to the pin.</TD></TR></TABLE>
so the rod just grips pin into place?
Old Jul 15, 2004 | 01:09 PM
Rocket's Avatar
Yes. It hold's it pretty tight. You'll realize this if you ever try to remove a pin from a stock honda rod.
DOHC_C-REX
34
May 15, 2008 06:23 PM
bzyq2001
Sep 21, 2007 04:06 AM
NA JDM GSR
Nov 15, 2006 07:06 PM
anrkii
Oct 5, 2006 07:56 AM
MI4$DC5
Mar 5, 2005 04:56 PM
