Any interest in a Spoon style bolt on caliper?
Old Nov 23, 2001 | 07:21 AM
fastbrakes's Avatar
Default Any interest in a Spoon style bolt on caliper?
These calipers have dust seals and easily obtained rebuilding parts(unlike the Spoons).
I'm ordering a caliper Monday to see what needs to be done to make it a direct fit.
I don't know what they will sell for, but if I can make them it will be way less than the $1400 that the Spoons cost.
Old Nov 23, 2001 | 07:50 AM
Zeus's Avatar
Default Re: Any interest in a Spoon style bolt on caliper? (fastbrakes)
Porsche Boxter calipers? or something that will actually bolt straight to the spindle?
Old Nov 23, 2001 | 08:00 AM
RR98ITR's Avatar
If you can do it in such a way that there is a free space between the caliper and the hub for ducting air then you might have something I'd be interested in. The dogbone adapters and similar methods of mounting prevent there being an open path (as with the stock caliper bracket). If you've seen how RTR mounts their Brembo calipers on little cube standoffs you know one solution.
Old Nov 23, 2001 | 08:42 AM
fastbrakes's Avatar
Default Re: Any interest in a Spoon style bolt on caliper? (Zeus)
Let's just say they are made in Europe and everyone knows the name.
I plan on making them bolt directly to the spindle just like stock. There should be enough room for ducting to get air between the caliper and the spindle for better cooling.
Old Nov 23, 2001 | 04:19 PM
ITR1227's Avatar
You can count me in on the "interested"! Is AP a good guess?!
Jeremy
Old Nov 23, 2001 | 06:27 PM
Dee's Avatar
Dee
Default Re: Any interest in a Spoon style bolt on caliper? (ITR1227)
Brian...
You might want to check the RSX-R calipers since according a Japanese Integra mag they are supposed to mount directly to '98 spec spindles.
[Modified by drealgsr, 7:33 PM 11/23/2001]
Old Nov 23, 2001 | 07:12 PM
chrisJ's Avatar
New User
Yes...defenitely interested. I have been looking for an alternative to spoon calipers, but i want something that bolts in directly. looked at AP and tar-ox (6-pot)
please keep us posted!
Old Nov 23, 2001 | 07:54 PM
ITR#132's Avatar
Default Re: Any interest in a Spoon style bolt on caliper? (drealgsr)
Brian...
Arent the calipers on the 98 spec in the front and the RSX-R in the rear?? Please clear this up as I am not to familiar on the brakes.
Old Nov 23, 2001 | 10:54 PM
Zeus's Avatar
"OE" ...now there's an interesting thought...
Old Nov 23, 2001 | 10:59 PM
Mike M's Avatar
Founding Member
It is possible, just need the rotors and calipers from a DC5R or AP1, but it wont fit under a 15" wheel
Old Nov 26, 2001 | 11:13 AM
fastbrakes's Avatar
I looked at the RSX when it came out and it looks like the calipers are the same general design as the rest of the Honda line. The caliper bolt spacing is the same so they will bolt on that way. I have not been able to find the specs on the rotors yet. As soon as I can confirm the specs I'll let you all know. The stock calipers will not fit under 15" wheels as the rotors are 11.8", but that means I might be able to use the rotors for a 4 piston conversion with the stock wheels
B_Swapped93
Mar 2, 2015 10:15 PM
niteridaV2
Dec 15, 2013 09:03 PM
Fly ef8
Dec 14, 2012 10:25 AM
99SlammedCivic
Suspension & Brakes
10
Jun 15, 2009 12:22 PM
dasistheone
Apr 15, 2006 01:35 PM
