BONDO n FIBERGLASS, Can You Remove Them Easily? Basically dericing my car
Old Jul 14, 2004 | 10:34 PM
Full Race A6's Avatar
Default BONDO n FIBERGLASS, Can You Remove Them Easily? Basically dericing my car
So Ive drove my Crx around for last year and this the second summer. The body work I did must have been shitty because it seems to be cracking/chipping already.
What I have is a fully molded Invader body kit and I had some rusty rear quarter panels so I just cut out the rust and threw some fiberglass over it annd by the time I was done fiberglassing/bondo, it looks like a wide body. Honestly I get that comment alot.
:Yo is that a wide body Crx kit:
There really is that much **** there.
So I was wonderring if its possible to buy something that I can remove all this **** easily.
Theres also a mound on the bottom of my doors but Ill be buying a wings west Rs kit so it has door caps so the rust will be coverred with the bondo removed
I will be doing this all after this summer/maybe earlier. I jsut dont want to sell the car because I have the entire floor/frame redone with countless hours of welding.
Just wanna change the body
Thanks for any info
Old Jul 15, 2004 | 12:27 AM
JCracer723's Avatar
Default Re: BONDO n FIBERGLASS, Can You Remove Them Easily? Basically dericing my car (W O T)
i wanna see pics of thise
lots of sanding
Old Jul 15, 2004 | 12:30 AM
mEr's Avatar
mEr
Default Re: BONDO n FIBERGLASS, Can You Remove Them Easily? Basically dericing my car (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">i wanna see pics of thise
lots of sanding </TD></TR></TABLE>
yeah, pics would help out a lot for us to reccomond what to do..
Old Jul 15, 2004 | 03:57 AM
darkcvc's Avatar
Blue Sedan Crew
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">
a new car
Old Jul 15, 2004 | 04:14 AM
Thrashin's Avatar
Default Re: BONDO n FIBERGLASS, Can You Remove Them Easily? Basically dericing my car (darkcvc)
its not worth it
Old Jul 15, 2004 | 08:56 AM
Default Re: BONDO n FIBERGLASS, Can You Remove Them Easily? Basically dericing my car (thrashin)
Why is it not worth it? The floor is immaculate and will last forever, the interior is also mint and the engine was just swapped.
Do you guys think that Aircraft paint Remover would take off the bondo as well?
**** would that ever help
Old Jul 15, 2004 | 09:51 AM
Bity bump
Old Jul 15, 2004 | 10:24 AM
88's Avatar
88
the only way to know is to try it but i dought it will
also, can you post a pic of your car?
Old Jul 15, 2004 | 10:59 AM
Default Re: BONDO n FIBERGLASS, Can You Remove Them Easily? Basically dericing my car (88)
no pics sorry, camera is in the shop because it got wet
Old Jul 15, 2004 | 11:19 AM
JCracer723's Avatar
i dont get it tho... u cut the rust and you threw some bondo and fiber glass?? and now u want to remove it?? i take so u can replace that whole mess with either a new quarter panel or well some metal where the rust was at??
if so.. just cut that **** out... grinder... Reciprocating Saw
Old Jul 16, 2004 | 12:55 AM
ALOT OF FIBERGLASS!
To mcu mess and time to get rid of it all, and 3 cans or whatever cant be to much, just spray it on, on the side of the road, scrape it off and voila
Just wanna know if it will work or if any other products will
Old Jul 16, 2004 | 01:12 AM
NrG's Avatar
NrG
You have to sand it down. It will take a lot of work but that is how it's done.
******* ricer..
Old Jul 16, 2004 | 01:27 AM
Gump's Avatar
Any body panel that can be unbolted should be replaced with new/used body panels, and you said you welded on a new floor, then do the same with the quarter panel.
Old Jul 16, 2004 | 09:56 AM
Default Re: (Gump)
That floor cost me $500
Dunno If Ill have the cash to get the quarters rewelded
Old Jul 16, 2004 | 10:12 AM
menkio's Avatar
Default Re: (W O T)
PICS !!
Old Jul 16, 2004 | 10:57 AM
Default Re: (DewMota)
Dont have any pics or my camera back. Ill make a thread of the buildup, but I need an easy remove for this stuff
Andresej1
Oct 18, 2017 09:01 PM
eros18
Paint and Body
Jan 14, 2011 07:55 AM
loumacri07
Paint and Body
19
Jan 7, 2008 07:24 PM
crexer
Oct 13, 2002 09:37 PM
MilanoRex
Feb 12, 2002 03:17 PM
