NO FUEL?????? NO FUEL?????? NO FUEL?????? please help!!!!!
i took a vocation for 3 weeks and when i returned..my car wouldnt start...before i left i had the car parked inside the garage and when i got back my car was parked at the back yard under a tree....i told my friend about my car not starting and he said that it might of been because of the heat....well today i try starting it up again and wasnt working...i notice my fuel pump is not comming on when the key is turned to ignition...so then i thought my fuel pump when bad so i connected the fuel pump directly to the battery and it worked fine...i disconnected the fuel line from my fuel rail and fuel was comming out..but when ive have it connected right..it doesnt work.... my thought is that it could be my fuel pump relay???
i'm not sure what it is so if any of yah could help..i would be very appreciated...!! thanks..
So, did someone move your car? Did someone you know move it? Did someone who wasn't supposed to be there move it? Weird. Once upon a time, I fried my computer. It seemed to have that same problem. The fuel pump wasn't whirring back there and I was stumped. I looked in the book and found some references to the PGM-FI Main relay. I spent two days looking for and cursing that thing. When I finally found it and replaced it, nothing happenned. Blah blah blah blah... It turned out to be my computer. You might want to check the PGM-FI main relay. It is located behind the change dish on the left of the steering wheel. It is a pain to get back there to take it off but you can unplug it and plug one from a friend's car to check it. I hope this helps.
actually one of my bro had moved my car...i'm still stuck and dont know where to check?? i guess the next thing i'll check is the ecu... HELP PLEASE!! thanks..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">Main relay.</TD></TR></TABLE>
well just wanna say i fixed my car....found out that the ecu wasnt powering all because of a bad fuse...just want to thanks all yah that was trying to help..
Cameron60
Jan 16, 2007 06:04 PM
