Tranny fill problem!!
Old Jul 14, 2004 | 07:42 PM
zcrxt's Avatar
Default Tranny fill problem!!
Ok so the tranny fill bolt is stripped? I have tried a few things but can not get it broken loose. I have search and found that you can fill through the vss but i can not get the vss off. I need help. Anyone with any ideas would be appriciated. Thanks guys!
Ben
Old Jul 15, 2004 | 07:29 AM
zcrxt's Avatar
Default Re: Tranny fill problem!! (89zchf)
Old Jul 15, 2004 | 07:32 AM
essex's Avatar
What do you mean stripped
stripped as in :
the threads are fucked and the bolt just turns in the whole
or the head is rounded off?
Old Jul 15, 2004 | 08:12 AM
zcrxt's Avatar
i mean that the head is rounded
ben
Old Jul 15, 2004 | 08:15 AM
essex's Avatar
try vice grips
if is way too rounded then get a grinder and make the edges flat so you can grab it with vice grips. Clamp the grips on super tight...use 2 hands. Should work.
Old Jul 15, 2004 | 08:20 AM
zcrxt's Avatar
Default Re: Tranny fill problem!! (essex)
only bad thing its is in such a tight space? any other ideas?
thanks
Ben
Old Jul 15, 2004 | 08:21 AM
spcrxracer's Avatar
go to your local hardware store. they make a special bit for things like this. Trust me i used to work at one.
Old Jul 15, 2004 | 08:30 AM
EFSiR's Avatar
or drain the old fluid, and place the correct amount (measured to the drop) of oil through top of your casing via your speedo gear hole.
Old Jul 15, 2004 | 08:31 AM
crx_88_si's Avatar
ya i think craftsman has something that takes out stripped bolts w/ a hex head
Old Jul 15, 2004 | 08:33 AM
zcrxt's Avatar
Default Re: (crx_88_si)
to fill through the speedo cable dont you have to remove the vss first correct? I tried removeing this but it wont come loose?
Ben
Old Jul 15, 2004 | 08:34 AM
EFSiR's Avatar
Default Re: (89zchf)
Yes, remove the vss, one 10mm long bolt, just wiggle it side to side, the o-ring probably is fried a bit.
Old Jul 15, 2004 | 09:19 AM
zcrxt's Avatar
Default Re: (EFSiR)
what does the vss look like when it comes out?
Any pics
Thanks
Ben
Old Jul 15, 2004 | 09:41 AM
stickershop.ca's Avatar
You can also fill it through the hole for the reverse light switch. But these alternate fill methods are just a temporary measure. Focus on getting the problem fixed. I had one that was really stuck once and had to used a pole on the end of the wrench and hit it with a dead-blow hammer several times. If you can get something to grab onto the stripped head of this bolt, I would try using an extension bar to get more leverage on it.
Old Jul 15, 2004 | 07:14 PM
zcrxt's Avatar
Default Re: (stickershop.ca)
Thanks guys H-T always comes through. I filled the tranny through the reverse light switch. Thanks again guys
Ben
alscrx
Jul 30, 2009 04:46 PM
C1power
Jan 7, 2006 03:27 PM
ccivic
Welding / Fabrication
Aug 24, 2005 02:03 AM
valentinecr
Jun 7, 2005 07:11 PM
team2n1hatch
Jun 30, 2003 04:00 PM
