trying to install kill switch, and no, i couldn't find the answer from the serach menu.
Old Jul 14, 2004 | 07:02 PM
suprman1124's Avatar
Default trying to install kill switch, and no, i couldn't find the answer from the serach menu.
i wanna install a kill switch on my 89crx si. and before ppl start b*tching at me for not using the search function, i did and all i need to know is what color is the wire im suppose to splice from the fuel pump. just got the crx with a 2 month old zc in it, hence the trial user. hehe, sold my 240 hatch and decided to go for cheap speed. and btw, this is a great forum. some jerks though who wanna make u feel bad for asking beginner questions. haha
Old Jul 14, 2004 | 08:00 PM
Default Re: trying to install kill switch, and no, i couldn't find the answer from the serach menu. (suprman
bump it
Old Jul 14, 2004 | 08:06 PM
EF9Si-T's Avatar
What color wires are exposed is it black and orange ? If so go for the orange other wise any other one except the black one will work. Actually even the black will work but your better off going for power than killing the ground.
Old Jul 14, 2004 | 08:26 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUG_MANIAC &raquo;</TD></TR><TR><TD CLASS="quote">What color wires are exposed is it black and orange ? If so go for the orange other wise any other one except the black one will work. Actually even the black will work but your better off going for power than killing the ground.</TD></TR></TABLE>
Grounds are just as important as power supplies, With no ground its not going to turn on. Same with the power
basicly any line off of the fuel sender unit (right under rear seat) can be swiched,
it needs all of those lines to function, without them all....no start
Most peole however just route the swich to the power wire.
not flaming your just a friendly suggestion, when you search, check the 'Archived content' button. I did a quick search and came up with a thread that contained this very informative link.
Enjoy : http://www.courtlukens.com/cutoff_switch.htm
Modified by HatchBox at 12:41 AM 7/15/2004
Old Jul 14, 2004 | 08:55 PM
EF9Si-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by HatchBox at 12:41 AM 7/15/2004</TD></TR></TABLE>
Guy I do know all this info but believe me the body of some of these fuel pumps is metal and ground current can still flow through the pump body to the chassi of the car, hence getting ground and being opperable. what good will it do to kill the ground through the wire if the pump will still be grounded and fully functional!!
Oh, by the way I know this because I've changed a couple of honda fuel pumps and explored the housings and found out the ground wire goes all the way into the tank and is bolted right on to the the housing, not because some told me!
cool, thanks a lot, read that same link but since he did it on a civic, i just wasnt sure what color wire it was on a crx but thanks for clearing that up
Old Jul 14, 2004 | 09:01 PM
HatchBox's Avatar
Skoobie no more...
good call, now that u mention it,
&lt;&lt;&lt;has is gas tank sitting in the garage and just did fuel pump install and i see exactly what you are saying...
Stick to the green/yellow wire
DO/\/\O
27
Dec 11, 2010 10:10 AM
unclejemima
41
Jul 11, 2004 07:31 PM
91 POS
Dec 11, 2003 04:47 AM
StreetRacnGsR
May 25, 2003 02:32 PM
RyanR
Jul 10, 2001 11:28 AM
