2awg equipment wire for big 3 upgrades?
Old Jul 14, 2004 | 06:51 PM
bassisliffe's Avatar
Default 2awg equipment wire for big 3 upgrades?
ok at work ive got alot of machinery with 2awg wire
a technician told me today where i can get 2awg wire for cheap with conectors put on the ends and i want to upgrade all power and ground wires, im talking starter alternater fuse box all ground wires
Old Jul 14, 2004 | 07:12 PM
EBP_SI's Avatar
Default Re: 2awg equipment wire for big 3 upgrades? (bassisliffe)
ok. the point?
Old Jul 14, 2004 | 07:41 PM
Default Re: 2awg equipment wire for big 3 upgrades? (EBP_SI)
i need to know if the wires i see on the machinery at my paving company can be used in my jeep as power/ground upgrades
Old Jul 15, 2004 | 06:36 PM
Eric R's Avatar
NO!
Old Jul 15, 2004 | 06:54 PM
Default Re: 2awg equipment wire for big 3 upgrades? (Eric's R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eric’s R &raquo;</TD></TR><TR><TD CLASS="quote">NO!</TD></TR></TABLE>
why not? arent ground wires for tractors and generators the same as fround wires for cars?
are you telling me the audiopipe wire i buy for my amp is better to use??
Old Jul 15, 2004 | 08:19 PM
fcm's Avatar
fcm
Old Fart
as long as its TEW [ multi strand wire ] I can't see why not. 94
Old Jul 16, 2004 | 12:29 PM
Default Re: 2awg equipment wire for big 3 upgrades? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> as long as its TEW [ multi strand wire ] I can't see why not. 94 </TD></TR></TABLE>
it is! but id still like the "NO!" explained
Old Jul 16, 2004 | 09:40 PM
nsxxtreme's Avatar
You will be fine. I use 2 awg welding cable at $1.20 a foot. Works great! There is nothing special about power wire.
Old Jul 16, 2004 | 10:11 PM
fcm's Avatar
fcm
Old Fart
Default Re: 2awg equipment wire for big 3 upgrades? (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">You will be fine. I use 2 awg welding cable at $1.20 a foot. Works great! There is nothing special about power wire.</TD></TR></TABLE> I bet the welding cable is better, better copper, more strands. better jacket ,[resistent to most chemicals] 94
Old Jul 17, 2004 | 12:09 AM
philly-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> I bet the welding cable is better, better copper, more strands. better jacket ,[resistent to most chemicals] 94</TD></TR></TABLE>
stiffer, less strands and thinner jackets too. its your car, go ahead and use welding cable.
yes it will work and no most people probably wont be able to tell the difference between "welding" cable and "power" cable, but they make it for a reason. yes the more strands that are present, the better the current flow and it also makes it much more flexable too.
just my $.02
Old Jul 17, 2004 | 05:20 AM
Default Re: 2awg equipment wire for big 3 upgrades? (peichie)
ok great! still want the NO! explained...
Old Jul 17, 2004 | 12:17 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peichie &raquo;</TD></TR><TR><TD CLASS="quote">
just my $.02</TD></TR></TABLE>
Actually you are wrong. The welding cable had more strands. Before you state things you think you know as facts you might want to go to your local welding shop. Wouldn't you think a welder would like to be able to move his welding rod in any direction he wanted? The jackets are much more durable that normal power wire jackets. Hell if I was a welder and had 480 volts running through a wire that jacket better be damn durable.
Yes they do make high end power wire for a reason. To take your money.
Old Jul 17, 2004 | 02:12 PM
philly-O's Avatar
my point is that car audio cable is specifically designed for the automotive environment. meaning the extreme temperature changes, chemicals found in the automotive environment and the shielding is designed for high vibration and cutting or rubbing through the jacket. there are reasons other than taking your money for car audio wiring also i have only seen welding cable in black, and that isn't the best color for power wire in the vehicle. in addition to using any "type" of 2ga wire, the accessories are alot more and harder to find since it is not a commonly used gauge.
Old Jul 17, 2004 | 03:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peichie &raquo;</TD></TR><TR><TD CLASS="quote">my point is that car audio cable is specifically designed for the automotive environment. meaning the extreme temperature changes, chemicals found in the automotive environment and the shielding is designed for high vibration and cutting or rubbing through the jacket. there are reasons other than taking your money for car audio wiring also i have only seen welding cable in black, and that isn't the best color for power wire in the vehicle. in addition to using any "type" of 2ga wire, the accessories are alot more and harder to find since it is not a commonly used gauge. </TD></TR></TABLE>
im not thinking of using it for power wire in the vehicle
just as ground and power upgrades in the engine
on my compressor for example it has 2 awg red wire for the starter and alt and 2awg black wire for the grounds
thats what i want to do with it, id never use it for power wire to be used in the audio system
Old Jul 17, 2004 | 05:28 PM
fcm's Avatar
fcm
Old Fart
Yes they do make high end power wire for a reason. To take your money.</TD></TR></TABLE> When I became an installer , 30 years ago, there were no monster, stinger, PH gold, EFX. so we used welding cable, and I still do to this day, my "shop" wire is Blue Streak welding cable.
Today our EFX rep. was in the store to show us there new line, and he brought in a 100 ft roll of there new "yellow" 8ga power wire , well I just happend to have a 100 ft roll of blue streak welding cable, and after sitting through the shpeel about the new wire, I got out the DMM and did a resistance test on both,
EFX=7.390 OEMs
Blue streak 0.763 OEMs 94
Wazup
Apr 18, 2011 04:04 PM
2point2
Jan 12, 2007 01:29 PM
teferi
25
Sep 6, 2006 01:37 AM
vidanator
Aug 30, 2003 05:25 PM
Trigun
Apr 16, 2002 08:48 AM
