swaping engine from a honda civic into a acura integra
Old Jul 14, 2004 | 01:55 PM
hon's Avatar
hon
Default swaping engine from a honda civic into a acura integra
i want to know can this work i have a 88 honda civic and a 87 acura integra,they are both 5speed,i want to swap the civic into the integra.will this bolt up,thanks
Old Jul 14, 2004 | 02:39 PM
Kendall's Avatar
No, the mounts are different. I'm not sure as to whether there are kits to perform this exact swap
Old Jul 14, 2004 | 04:25 PM
hondaguyef's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">No, the mounts are different. I'm not sure as to whether there are kits to perform this exact swap</TD></TR></TABLE>
You sure? I think if you use the mounts and brackets from the teg that the SOHC will bolt in. Yeah i am pretty sure that this will work. The engine in the teg is basically the same (appearance and mounting) as the DOHC ZC. Yes this will work.
use the mounts and brackets from the teg on the sohc and it should bolt right in. you can also use the teg tranny and axles
Old Jul 14, 2004 | 04:44 PM
hon's Avatar
hon
Default Re: swaping engine from a honda civic into a acura integra (hon)
thanks guys hope this work
turbotime
May 1, 2007 01:29 PM
TeggyStylez
Dec 31, 2006 11:36 AM
BlingBlingCivic
Feb 24, 2005 09:38 PM
siboi18
Dec 19, 2003 06:16 PM
g-unit soldier
Oct 24, 2003 08:55 AM
