What timing belt to use?
Old Jul 14, 2004 | 01:03 PM
vr6chris's Avatar
Default What timing belt to use?
B18C1 bottom end with a b16a head. Gsr cams with b16 cam gears. Anyone know what timing belt to use. Already tried b20 timing belt(too small), b16 si timing belt(way too small), and the type r timing belt(too big). Thanks
Old Jul 14, 2004 | 03:25 PM
vtecb20coupe's Avatar
B A N N E D
Default Re: What timing belt to use? (vr6chris)
why wouldn't you have tried a gsr timing belt?
Old Jul 16, 2004 | 01:40 PM
smart monkey's Avatar
the gsr and R belt are the same size. what water pump do you have on that motor.
Old Jul 20, 2004 | 04:19 AM
93H22ACX's Avatar
Default Re: What timing belt to use? (smart monkey)
the b16 timing belt....is it for a del sol vtec or 99-up civic si?
http://www.Hondaautomotiveparts.com
99-up Civic SI timing belt PN: 18228
95 Del SOL VTEC timing blet PN: 102635
95 Del SOL SI timing belt PN: 102632
Old Jul 20, 2004 | 07:22 AM
B A N N E D
Default Re: What timing belt to use? (93H22ACX)
that's weird. the del sol vtec should be the same as the 99-00 si belt.
Old Jul 20, 2004 | 07:24 AM
93H22ACX's Avatar
Default Re: What timing belt to use? (vtecb20coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">that's weird. the del sol vtec should be the same as the 99-00 si belt.</TD></TR></TABLE>
thats what i thought too...
techsynthesis
13
Mar 4, 2008 09:19 PM
usdmEHboy
Feb 1, 2007 07:14 AM
crxtreme27
Apr 30, 2003 05:31 PM
90civichbsi
Jul 27, 2002 09:03 AM
twinkie
Jan 29, 2002 04:45 PM
