HELP, starter signal fuse...
Old Jul 14, 2004 | 12:53 PM
TIRENECK's Avatar
Default HELP, starter signal fuse...
What is link to the starter signal fuse that could stop it from getting power? All other fuses get power and when i turn the key the ecu blinks 1 short but no codes.
The car has been sitting for a while and it use to run and start with no problems. Im also not getttig spark but I want to make it turn over first than troubleshoot the spark issue, help me out yo.
Old Jul 14, 2004 | 02:04 PM
im_poor's Avatar
Default Re: HELP, starter signal fuse... (TIRENECK)
the starter fuse won't get power until you turn the key and try to crank it, your using a test light I assume?
Old Jul 14, 2004 | 02:12 PM
TIRENECK's Avatar
Default Re: HELP, starter signal fuse... (im_poor)
yep, either way the starter doesnt crank when I turn the key.
Old Jul 14, 2004 | 02:47 PM
im_poor's Avatar
did you check the wires to make sure there connected on the starter.
Old Jul 14, 2004 | 09:04 PM
TIRENECK's Avatar
yes starter is plug in and has power but since i cany make it to crank with the key i gave it direct power from the battery and it cranks. The starter is out of the picture.
nestea8869
10
Mar 26, 2022 10:12 AM
artben57
Oct 2, 2017 06:35 AM
Hondaacc95
Apr 26, 2010 10:34 AM
JLefevers
Jun 5, 2007 07:05 AM
