crx si b17 swap, what wiring do I need?
well you are already wired for fuel injection so youll have to wire in vtec and and swap over to obd1 if you want. you can get complete wiring harnesses from hasport and i think maybe hcp too. then all you have to do is plug it all in.
yes, you use the stock Si harness on the b17a. if you want to keep the motor obd1 and use the b17a obd1 ecu, then you will need to hack off the distributor plug from the b17a harness and wire it up in place of the Si distributor plug on the Si harness. then you'll need an obd0 --> obd1 jumper harness, and you'll have to run extra wires for VTEC, Vtec Oil Pressure Sensor, Vtec Oil Pressure Sensor Ground, Knock, & 4-wire o2 sensor.
Tshoemaker
Dec 29, 2010 09:46 PM
importgod21682
Dec 25, 2006 09:33 AM
cccya
Jul 17, 2004 11:21 AM
