Differences between Si and HF harness
Old Jul 14, 2004 | 12:07 PM
b18cx's Avatar
Default Differences between Si and HF harness
Yes, did a search, but you cant search 2 letter terms.
Does anyone know exactly what is different between these two harnesses.
the origional harness is not an option here, as the guy gave away the origional motor and harness.
Old Jul 14, 2004 | 12:10 PM
crx_88_si's Avatar
Default Re: Differences between Si and HF harness (b18cx)
you will have to re-pin the shock tower harnesses to match the ecu harness.
the HF wires are the same as the SI except they are pinned differently.
Old Jul 14, 2004 | 12:24 PM
b18cx's Avatar
Default Re: Differences between Si and HF harness (crx_88_si)
Any helpful pin out web sites that could save some time here?? Can do it with a multimeter, ecu pinout, a case of beer, and a **** load of time.
Old Jul 14, 2004 | 01:25 PM
Jester88Si's Avatar
Why not use the harness that belongs on the car??
Old Jul 14, 2004 | 01:32 PM
NCchris's Avatar
Default Re: (Jester88Si)
The HF harness has a plug for EGR valve and the Si has a plug for FICV and they are pinned differently at the pass shock tower.
HTH
chris
Old Jul 14, 2004 | 01:35 PM
b18cx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jester88Si &raquo;</TD></TR><TR><TD CLASS="quote">Why not use the harness that belongs on the car??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cx &raquo;</TD></TR><TR><TD CLASS="quote">......the origional harness is not an option here, as the guy gave away the origional motor and harness.
Old Jul 14, 2004 | 01:54 PM
b18cx's Avatar
Default Re: (NCchris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCchris &raquo;</TD></TR><TR><TD CLASS="quote">The HF harness has a plug for EGR valve and the Si has a plug for FICV and they are pinned differently at the pass shock tower.
HTH
chris</TD></TR></TABLE>
But that would not cause the "No Spark" problem. thinking I need to check the ecu to Distributor connection.
Does anyone have the Distributor pinout, either by function or ecu location??
Old Jul 15, 2004 | 11:00 AM
b18cx's Avatar
Default Re: (b18cx)
Got it started last night. Let me say, THERE ARE SOME MAJOR DIFFERENCES!!!!. Even though everything plugs up and colors look right, there not. I am going to take pics and document everything for future use. I'll post in the FAQ section when done.
Old Jul 15, 2004 | 11:22 AM
UltimX's Avatar
What do you mean the pinned differently at the pass shock tower? Whats so different?
Old Jul 15, 2004 | 01:07 PM
b18cx's Avatar
Default Re: (UltimX)
Right off hand, The large white wire at the dist. that supplies power to the ignitor, traces back to the pass. shock tower in the SI engine harness, but on the HF chassis, that wire is in the plug on the drivers side next to the resistor box. IAC is located else where as temp sending unit, and IAT. Tracing those down tonight.
The HF chassis is pinned differently. If thats how you want to look at it.
Other things I noticed, injectors are pinned different. Distributor is all correct except for the wire mentioned above.
Old Jul 15, 2004 | 01:10 PM
crx_88_si's Avatar
Default Re: (b18cx)
this is why you modify the harness that your car ORIGINALLY came with
good work on figuring it out.. now get that write-up!
crx89backedout
Jan 14, 2010 03:36 AM
lemongreenhatch
10
Dec 12, 2004 10:11 PM
markgo
Feb 29, 2004 06:13 PM
ITSTOCK
Nov 15, 2003 03:51 PM
