reving to 9500 ls vtec
Old Jul 14, 2004 | 10:05 AM
FastAllmotorLsVtec
Guest
Posts: n/a
Default reving to 9500 ls vtec
what crank would you use?everything this else is built
Old Jul 14, 2004 | 10:31 AM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: reving to 9500 ls vtec (FastAllmotorLsVtec)
bump
Old Jul 14, 2004 | 12:54 PM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastAllmotorLsVtec &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
a gsr crank.. but that wouldn't reall make it an ls/vtec now would it?
Old Jul 14, 2004 | 01:03 PM
jaydmcrx's Avatar
Wouldnt the stock ls crank rev just fine with a good balancing??? Rod bolts, rods, are a huge factor as well.
Old Jul 14, 2004 | 01:11 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (jaydmcrx)
eagle rods?ya i know but can the ls go to 9500?what happens when it gets balances?
Old Jul 14, 2004 | 01:32 PM
DonF's Avatar
Default Re: (FastAllmotorLsVtec)
If you are running LS rods you are living on borrowed time.
Old Jul 14, 2004 | 01:37 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (DonF)
im not running ls rods!
what you mean by borrowed time?
Old Jul 14, 2004 | 03:22 PM
vtecb20coupe's Avatar
B A N N E D
he means the block won't last long. which is not necessarily true. the arp rod bolts are meant to help out for higher revving motors.
Old Jul 14, 2004 | 03:25 PM
nY's FiNeSt's Avatar
Default Re: (vtecb20coupe)
why u wanna rev to 9.5, what cams u gonna use?
Old Jul 14, 2004 | 03:30 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (nY's FiNeSt)
jun 3 or toda
Old Jul 14, 2004 | 03:52 PM
tegasaurus's Avatar
if you really are going to rev that damn high, plz get an itr or gsr oil pump to provide oil to the bearings so that they don't prematurely turn into barf like mine did.
Old Jul 14, 2004 | 04:05 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (tegasaurus)
ya i will does it matter which one itr or gsr?also running 14.5:1 over 105 octance can you use msd or will it go BOOM! ?
Old Jul 14, 2004 | 04:15 PM
alloutmotor's Avatar
u can use which ever crank u prefer, since it seems as if you are going all out u should balance the whole rotating assembly
and what are u going to use MSD to do , Ignition?
go with a good Engine management, u cant cheap out when it comes to engine management
Old Jul 14, 2004 | 04:17 PM
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">if you really are going to rev that damn high, plz get an itr or gsr oil pump to provide oil to the bearings so that they don't prematurely turn into barf like mine did.
true, no point in turning something vtec if you're not going to add vtec parts.
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (alloutmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alloutmotor &raquo;</TD></TR><TR><TD CLASS="quote">u can use which ever crank u prefer, since it seems as if you are going all out u should balance the whole rotating assembly
go with a good Engine management, u cant cheap out when it comes to engine management</TD></TR></TABLE>
ya msd ignition , what a good engine management system if i switch the crank there no point calling it ls vtec but it still will work like one rite?
whats an good air fuel ratio guage?
Old Jul 14, 2004 | 04:20 PM
sander's Avatar
2.7(p/t)
I dont want to start a huge RS argument, although you should know.
Rod stroke ratio is a large factor when determining rev limit.
Lower RS motors make more power lower (stroker motors).
Higher RS motors make more power up high for the most part (de-stroked motors)
If you rev the crap out of a Lower RS motor and plan on having long term use out of it you may want to think twice.
An ideal RS is 1.7~
The LS is 1.54
The GSR is 1.58
I AM NOT SAYING LS HAS BAD RS RATIO. Im saying you may want to think twice about revving near 10k. And thats based on wheather you can even make power that high on an LS crank and still be streetable (have good low end power too).
Just fyi.
-sander
Old Jul 14, 2004 | 04:22 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (sander)
how can you make RS higher?
Old Jul 14, 2004 | 04:27 PM
sander's Avatar
2.7(p/t)
getting gsr crank.
But thats alot of work for not much gain. Just set your motor to take advantage of the lower RS and enjoy the power a bit lower.
If you want to rev to 9500 all day long get a b16 (in a street car).
Race car is diffrent.
-sander
Old Jul 14, 2004 | 04:41 PM
FastAllmotorLsVtec
Guest
Posts: n/a
not much again but still there is some
the power lower what can i do to give me some power higer? wont elebroke im help me out
Old Jul 14, 2004 | 04:42 PM
DefiantGSR's Avatar
that's a lot of compression for just Jun IIIs
Old Jul 14, 2004 | 04:44 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: reving to 9500 ls vtec (DefiantGSR)
so youre saying todas then?
someone said on here jun 3 are fine what about jun 4 ,drag?
Old Jul 14, 2004 | 04:45 PM
Combustion Contraption's Avatar
RS ratio isnt the most important factor when determining longevity of an LS vtec. Piston speed is. Take a look at this. Both figures are in feet per minute at 9500rpm. This is the TRUE reason LS/Vtec isnt as reliable. The bearings are just getting ******* POUNDED at righ rpms. Thats why they spin. Not because of shitty oiling problems caused by the oil line to the back of the head, or any other stupid excuses. (besides oil pump, but an oil pump shattering on ANY motor would be deadly to your bearings.) Hope ive helped out a little.
B16=4779.45 fpm
LS=5495.75 fpm
Old Jul 14, 2004 | 04:48 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (LsVtec92Hatch)
ok jeez then how did back years ago did eugene rev to 9500?and not this is not the reason why im doing my ls vtec
theirs no way to keep a bearing from spinning besides not reving so high
Old Jul 14, 2004 | 04:54 PM
*sigh*
first of all, whose eugene?
second of all, you cant argue with physics.
third of all, you can spin a bearing at any RPM, its just easier up high.
Old Jul 14, 2004 | 04:55 PM
FastAllmotorLsVtec
Guest
Posts: n/a
eugene from mtv true life
