ride hieght and lowering question?
I just put some Enkei RS6 rims with 195/50/15s on my EG HB and I noticed that in the rear it filled out the wheel wells nicely ...
In the front it looks a bit high and I was wondering if anyone has just lowered the front so it looks like the back and what is your opinion on the following shocks/coil overs
http://cgi.ebay.com/ebaymotors...33586
thank you all
thank you all
stay away what ever you do do not buy those hunks of **** i am so sick of people bringing me those peices **** to get put on and then bitching about how much they suck if you are going to get coil-overs get ground control i can hook you up with a brand new set of true ground control special editions for 300 plus shipping to you believe me you get what you pay for
i've had similar coil overs on my car before. usually the spring ratings on them are high and if used with oem shocks, it will make you cringe every time you come across imperfections on the road and that lowered at 2 inches all around. I got fed up with it so i got shocks. Check the spring ratings on them if they say anything near F/R 500/400, those things will be stiff.
Depending on how low you set them it will determine how bouncy they are. You know what's really good on our year civics for the front? koni yellows aftermarket shocks. You can have them put on AND set the perch lower and it will drop your at the front 1.5 inches in the front, if you're looking to get shocks you can go that route.
) the common suspension would be ground controls with kybs
