For those running 10's in street cars. What kind of power are you making?
375 aint gonna cut it. the guys running the 10's are usually at least in the 500+ range
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">375 aint gonna cut it. the guys running the 10's are usually at least in the 500+ range</TD></TR></TABLE>
I think if only took 375, there would be a lot more HTers in the 10s than there are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c »</TD></TR><TR><TD CLASS="quote">you plan to use the dx single came motor?
when did he ever hint that he was gonna use the d15? All he said was 375 hp in a dx hatch.
</TD></TR></TABLE>when did he ever hint that he was gonna use the d15? All he said was 375 hp in a dx hatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Crow »</TD></TR><TR><TD CLASS="quote">Can I get it done with 375 in a dx hatch?</TD></TR></TABLE>
It's going to take about 500 whp to do it in a hatch... Less hp with weight reduction.
Guest
Posts: n/a
400whp in a properly setup cx/vx hatch will do it if you can drive...Theres guys going 11.2-11.5 with 320-375. People don't realize its ALOT easier to make big numbers than it is to use them iin a honda. You need about a 130mph trap to run 10's. a 2200lb car with 400whp will trap right around there.
What are the weights on these cars? And are these all with slicks? In the latest DSPORT mag. there's a 10 sec. eg on drag radials...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Split Image Prez »</TD></TR><TR><TD CLASS="quote">What are the weights on these cars? And are these all with slicks? In the latest DSPORT mag. there's a 10 sec. eg on drag radials...
</TD></TR></TABLE>Please dont tell me this is the PFI car on nitto 205's
if your 1,800'lbs with you in the car it may can be done , other then that you need 440-460whp with a smaller turbo to get a good power to run mid to high 10's
Thanks guys. It looks like I'll be ordering a NOS kit also. I just don't think I can get 425hp from a stock bore b16 and a t3t4 48ar 50.
dont believe everything you read
</TD></TR></TABLE>dont believe everything you read
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">
dont believe everything you read</TD></TR></TABLE>
You think they are lying?
To answer your question, yes, I believe it could be done with 375 whp in a 2100-2300 pound car...Also many people are in such a big hurry to make the big horsepower #s, they forget to properly set up the suspension for drag racing...To give you an example, my car is a full weight 92 dx h/b, making 300 whp at best when I ran 11.7...This was pulling mid to high 1.7 60 fts...If I were to properly set the car up for drag racing, my 60 fts would be even better resulting in a better et with the same amount of horsepower...Drop a little weight, along with 75 more whp, and I think high 10s would be no problem...Also, you do not need 130 plus mph trap speeds to go 10s...Like I said, the car needs to be set up for a dragging...People on here before have went in the 10s with less than 400whp, and trap speeds around 125 mph....Just my .02
You think they are lying?</TD></TR></TABLE>
If there was a 10 second FWD car on drag radials EVERYONE would be talking about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">screw the nitrous, just upgrade the turbo </TD></TR></TABLE>
A little off topic here, but I'm curious what turbo you're using in your R pete?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr »</TD></TR><TR><TD CLASS="quote">To answer your question, yes, I believe it could be done with 375 whp in a 2100-2300 pound car...Also many people are in such a big hurry to make the big horsepower #s, they forget to properly set up the suspension for drag racing...To give you an example, my car is a full weight 92 dx h/b, making 300 whp at best when I ran 11.7...This was pulling mid to high 1.7 60 fts...If I were to properly set the car up for drag racing, my 60 fts would be even better resulting in a better et with the same amount of horsepower...Drop a little weight, along with 75 more whp, and I think high 10s would be no problem...Also, you do not need 130 plus mph trap speeds to go 10s...Like I said, the car needs to be set up for a dragging...People on here before have went in the 10s with less than 400whp, and trap speeds around 125 mph....Just my .02</TD></TR></TABLE>
I think it is possible with a good properly set up suspension and some good driving.
All these 500whp+ cars I have seen videos and they are fast but alot "not all" are blowing the tires off on the kick?
