Engine knocking
Old Jul 14, 2004 | 06:14 AM
greenmachine04's Avatar
Default Engine knocking
I have a 2000 civic dx and my engine started knocking yesterday. I was wondering can it be fixed or do i need a new engine. And if i do need a engine where can i get a good price on gsr, si, or ls engine.
Old Jul 14, 2004 | 06:24 AM
EGB18's Avatar
Default Re: Engine knocking (greenmachine04)
Thereare a couple of different reasons your engine may be knocking. But if you are looking for a new engine then check out the sites i've posted for you.
http://www.jhpusa.com
http://www.streetimports.com
http://www.jazzproparts.com <--- FREE Shipping on engines, mounts, intakes, everything.
Old Jul 14, 2004 | 06:28 AM
my dad says it may be i blew a rod or something
Old Jul 14, 2004 | 07:55 AM
skrewdriver88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenmachine04 &raquo;</TD></TR><TR><TD CLASS="quote">my dad says it may be i blew a rod or something</TD></TR></TABLE>
That could be one of the many things that can cause that. Start out by checking the basics and ****. Also make sure you have oil and **** in the engine.
Old Jul 14, 2004 | 07:59 AM
deeksmooth's Avatar
Default Re: Engine knocking (skrewdriver88)
well let the damn thing in already... don't leave it out in the cold.
if you're looking for a swap check hmotorsonline, i hear they're good... i have no experience w/ them though. go Big or go home
I changed the oil last night
Old Jul 14, 2004 | 08:02 AM
scratchy's Avatar
well first thing to check would be oil you might have low oil and not enough pressure, next check your valve lash you might need to tighten your valves or you might have a bad wrist pin on the piston if it comes down to the wrist pin junk the motor and go with your b-18 setup you want, good luck
Old Jul 14, 2004 | 08:09 AM
AccordDX89's Avatar
Default Re: Engine knocking (scratchy)
Could be bearings. Did you notice any metal shavings or flakes in your oil when you drained it?
Old Jul 14, 2004 | 08:41 AM
no the oil did not have any metal shavings or flakes
Old Jul 14, 2004 | 08:53 AM
what basic things should i check
Old Jul 27, 2004 | 01:52 PM
scratchy's Avatar
Default Re: (greenmachine04)
well you could get an automotive stethascope and use it to find out were the knock is coming from and that will point out the prob. any local autozone should have a stethascope
Old Jul 29, 2004 | 11:39 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenmachine04 &raquo;</TD></TR><TR><TD CLASS="quote">no the oil did not have any metal shavings or flakes
i had to drop my oil pan to see the shavings cuz they wouldn't drain out.
Old Jul 29, 2004 | 12:19 PM
JinDIESEL's Avatar
Default Re: (not so civic)
just change the engine.. totaljdm will treat you good.. they treated me good
1.6LitreDokeVeetak
Mar 7, 2007 07:33 AM
ZipTieGUy
Apr 25, 2006 04:23 PM
Papichulo1767
Aug 2, 2004 06:30 AM
rival12
Jul 25, 2004 04:54 PM
alexr9000
Jun 20, 2003 11:04 PM
