JDM H22 in 95 Accord EX..is running rich and rough?
Old Jul 14, 2004 | 04:38 AM
mrpaperpaper's Avatar
Default JDM H22 in 95 Accord EX..is running rich and rough?
hey guys, I just installed a 94 JDM H22 into my 95 Accord EX yesterday. Its up and running but stalls/bogs a little when you hit the gas pedal. It also does this when you switch gears? I advanced the timing and it doesnt do it no more, but the other problem is I have no Vtech. Is it okay if I use an Accord Vtech Fuel Pressure Sensor? My check engine codes are 22 and 10 and Ive tried everything but I cant get rid of these codes. I need some massive help for Im running out of ideas.
Old Jul 14, 2004 | 05:15 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: JDM H22 in 95 Accord EX..is running rich and rough? (mrpaperpaper)
Just a little FYI, you might want to say VTEC instead of VTECH. Some people really don't like that and will flame you for it.
I'm not familiar with what the codes stand for, what does code 22 and 10 stand for?
Old Jul 14, 2004 | 11:44 AM
pyrojeff's Avatar
Default Re: JDM H22 in 95 Accord EX..is running rich and rough? (TouringAccord)
10: IAT Sensor (Intake Air Temperature)
defective circuit or unplugged / defective sensor
22: VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
Old Jul 14, 2004 | 11:51 AM
-RedneckDave-'s Avatar
Working
YOu probably just need to replace the sensors which happens alot when motor swaps are done.
Old Jul 14, 2004 | 05:23 PM
KGAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">Just a little FYI, you might want to say VTEC instead of VTECH. Some people really don't like that and will flame you for it.
...especially since you spent a good amount of time installing and prepping the motor all the while it says VTEC in large letters on the valve cover.
Old Jul 14, 2004 | 07:55 PM
91wagon's Avatar
Default Re: JDM H22 in 95 Accord EX..is running rich and rough? (KGAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KGAccord &raquo;</TD></TR><TR><TD CLASS="quote">...especially since you spent a good amount of time installing and prepping the motor all the while it says VTEC in large letters on the valve cover.</TD></TR></TABLE>
Lol.
Old Jul 15, 2004 | 08:04 PM
hey hey my bad...Im new at this sh*t.....but thanks for the tips and info. The motor runs really strong...but I just dont feel the Vtec kick. Ive tried all kinds of ODB1 ECU. But sure thing, I'll try to find some new sensors. Could it be my wiring too?
Old Jul 15, 2004 | 10:46 PM
vroomvroomcivic's Avatar
who did the swap?
did they swap the a6 and a11 wires on the ecu? add knock sensor as well as the IAB? check your grounds? check everything
Old Jul 15, 2004 | 10:47 PM
Legendaryyaj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrpaperpaper &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, I just installed a 94 JDM H22 into my 95 Accord EX yesterday. Its up and running but stalls/bogs a little when you hit the gas pedal. It also does this when you switch gears? I advanced the timing and it doesnt do it no more, but the other problem is I have no Vtech. Is it okay if I use an Accord Vtech Fuel Pressure Sensor? My check engine codes are 22 and 10 and Ive tried everything but I cant get rid of these codes. I need some massive help for Im running out of ideas.</TD></TR></TABLE>
Its a good thing u dont have Vtech!
Old Jul 16, 2004 | 03:18 AM
Default Re: (vroomvroomcivic)
Me and my buddy did the swap. We didnt need to switch out any wiring. Everything plugged and played because I had an EX motor (SOHC Vtec). I didnt need to switch out a knock sensor wire or anything. He did the same swap on his accord and it was an LX model with out the knock sensor and Vtec so he did do what you implied to his car.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vroomvroomcivic &raquo;</TD></TR><TR><TD CLASS="quote">who did the swap?but yes I will check my grounds AGAIN. thanks
did they swap the a6 and a11 wires on the ecu? add knock sensor as well as the IAB? check your grounds? check everything </TD></TR></TABLE>
itsmeek
Oct 15, 2008 09:51 PM
itsmeek
Oct 9, 2008 09:11 AM
hondatuningboi96
Aug 24, 2006 03:11 AM
H22AJSPEC
Sep 10, 2003 08:33 PM
