96 Accord Speed Sensor Problems
Old Jul 14, 2004 | 04:13 AM
gjohnson4's Avatar
Default 96 Accord Speed Sensor Problems
I replaced the speed sensor and all was great for about a minute of driving and it stopped working again.? The car was shifting perfectly and then the check engine light came on and it began slipping and falling out of gear again. Could it be the wiring leading to the sensor? Would that give you a bad code also? Could it be the computer? My Haynes manual has about six lines about the sensor which essentially informed me that the sensor is located somewhere in the engine compartment...Please help!!
Old Jul 14, 2004 | 06:20 AM
Filthy Focker!'s Avatar
Default Re: 96 Accord Speed Sensor Problems (gjohnson4)
What did you do to diagnose this?
fs
Old Jul 14, 2004 | 11:34 AM
gjohnson4's Avatar
Default Re: 96 Accord Speed Sensor Problems (filthy_shovel)
I had a computer check run on it that came back with a vehicle speed sensor code (17). So, I replaced the vss. Do you think it is something else? Thanks for the reply.
Old Jul 14, 2004 | 04:12 PM
cd555's Avatar
Its an auto right? If so is the drive light blinking? If it is then whats the code?
Old Jul 15, 2004 | 05:07 AM
gjohnson4's Avatar
Default Re: 96 Accord Speed Sensor Problems (farroutt)
Thanks Farroutt,
The codes that came up were 17 and 54. Yes it is an automatic. The drive light is not blinking. I had a mechanic look at it yesterday and he told me the tranny was gone because the fluid wasn't bright red. I had the transmission flushed about three weeks ago and the fluid is now a deep purple color. He didn't run any type of diagnostics and said that when a vss goes out, it simply affects the gears from shifting. He said with the gears slipping, and now not engaging at all, that it must be the clutches are gone and the transmission must be replaced. I still think that it could be an electrical issue because when the car was reading the vss it ran perfect, am I wrong? Thanks again.
Old Aug 10, 2004 | 08:13 PM
draneusmc's Avatar
so what happended I am in the same situation here with my 98 lude automatic, should I change my tranny fluid and go from there? help!!!
maurif2
May 8, 2018 10:55 AM
janelectric
Aug 27, 2012 06:04 AM
CaptainObvious
Aug 18, 2003 04:41 PM
EFFECT
Sep 17, 2002 02:32 PM
