from Turbo to all motor. thinking of joining the club
Old Jul 14, 2004 | 01:06 AM
stockegsix's Avatar
Default from Turbo to all motor. thinking of joining the club
I'd be honest, Im not very familliar with all motor setups. Although Ive been reading about a lot of things related to NA, there are still many questions that need answers, you
can say Im still a little bit skeptical about all this.
Ive had a b16a turbo before but all it gave me were problems. I now have a b18c1 w/ just basic bolt-ons, and like everybody else I want more power.
current set up
stock b18c1
CTR intake cam
ITR 4-1 header
Skunk2 manifold
CTR N1 pulley
j's racing light weight flywheel
exedy stage one
p28 w/ jun chip
2.25 piping
es oval muffler.
My goal is 220hp NA trim, my budget would be around $1500. is this enough?
Old Jul 14, 2004 | 06:54 AM
BigBodySmith's Avatar
Default Re: from Turbo to all motor. thinking of joining the club (stockegsix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockegsix &raquo;</TD></TR><TR><TD CLASS="quote"> I'd be honest, Im not very familliar with all motor setups. Although Ive been reading about a lot of things related to NA, there are still many questions that need answers, you
current set up
stock b18c1
CTR intake cam
ITR 4-1 header
Skunk2 manifold
CTR N1 pulley
exedy stage one
p28 w/ jun chip
2.25 piping
es oval muffler.
My goal is 220hp NA trim, my budget would be around $1500. is this enough?</TD></TR></TABLE>
You will NOT be able to hit 220hp with the parts you have and with only $1500.00. You will need to run 84mm bore with high compression. Run some lumpy cams, ctr's might get you there , Hondata along with rc310s, and get rid of the ctr pulley, kills the oil pump, run a b16 pulley or the fluidampr. The header will probably need to be changed aswell. This will get you alot closer to your goal. So far it is a pretty good start. Good Luck
krndanic307
Aug 11, 2007 10:14 AM
fredsintegra
Dec 31, 2006 02:00 PM
Rev2 9K
Sep 28, 2005 08:42 PM
HT
13
Sep 23, 2004 05:05 AM
stockegsix
Mar 10, 2004 01:34 AM
