GSR/B16 swap
Old Jul 13, 2004 | 11:46 PM
CRseXxy's Avatar
Default GSR/B16 swap
i attempted to do a B16a motor swap into a crx, but found out the engine i was swapping in has a GSR head on it. i have the wiring harness and everything for a b16 obd-0 swap, do i have to go out and buy a new wiring harness or can i make the one i have fit? if not what other parts would i need to buy (distibutor, ecu, etc.)
Old Jul 13, 2004 | 11:48 PM
Sack Master's Avatar
Default Re: GSR/B16 swap (CRseXxy)
You'll be fine. You may have to modify the harness a small amount to compensate for the AIT. I don't think any of the plugs are different.
Old Jul 13, 2004 | 11:53 PM
CRseXxy's Avatar
Default Re: GSR/B16 swap (Sack Master)
the plugs didnt fit the injectors, and i'm pretty sure they wouldn't have fit the distributor. Someone said by an adapter kit, and what not... i also heard buy obd-1 injector plugs and everything else should fit. i'm gonna give it another shot on thursday, im just hoping to get some ideas before attempting it again
Old Jul 14, 2004 | 12:26 AM
Well if its an OBD0 wiring/ecu you are using then you will need OBD0 injectors and distributor. Just get those from a B16, they will fit fine. I'm sorry I didn't specify. But everything else should work fine.
Old Jul 14, 2004 | 06:42 AM
mmuller's Avatar
Mad Scientist
yeah, and just use a rpm activated switch for the iab's
Old Jul 15, 2004 | 05:08 PM
CRseXxy's Avatar
ok, ive succesfully switched the OBD-0 wiring harness over to the GSR head... on the B16 head however, there was a plug on the intake manifold by the 4th injector, and on my GSR intake manifold about the same spot there is a hole that looks like something should go there... besides that the distributor and plugs all fit perfect now
karmunkey
Aug 27, 2014 05:21 AM
tony7626
Mar 16, 2012 05:55 PM
ryanangelo212
Jan 16, 2010 01:42 PM
mitsuman
Mar 30, 2007 10:52 PM
