ls swap in a ek
Old Jul 13, 2004 | 09:19 PM
b16a1integra's Avatar
Default ls swap in a ek
ok i have a 96 cx hatch(very slow).i just got a 96 ls motor.i also have a set of 00 si mounts.everything is plug and play.now the ac backet i have from the si will fit????i have done my research............and every search is sayin to use 96-7 del sol vtec ac backet. if anyone as info please replie.
Old Jul 13, 2004 | 11:36 PM
J_SpeC_EK's Avatar
Default Re: ls swap in a ek (b16a1integra)
you can use any b-series a/c bracket. if you want the d-series a/c compressor to bolt up right, you have to use the dohc del-sol a/c bracket. If you use any other b-series a/c bracket i.e. SI, gsr, type r, wutever, only two bolts will bolt up to the compressor. if you like, IM me, and i can answer any questions you may have bout b-serious swaps in an EK. I've done like 5 myself. hope this helps.. good luck..
Old Jul 14, 2004 | 06:43 AM
Default Re: ls swap in a ek (J_SpeC_EK)
thanks for the info..............i will buy the del sol backet.i don't want to take any short cuts with my baby.do u happen to know the part number from honda?????
t_dot_SiR
Jul 1, 2006 09:23 AM
siblue_gzer
10
Jun 14, 2006 10:52 PM
1.8
12
Dec 18, 2004 06:36 PM
sleeperek
Jun 4, 2004 05:00 PM
allmtr
Jul 29, 2002 01:51 PM
