Ls vtec Knock Sensor problem...
Old Jul 13, 2004 | 08:27 PM
rusureboutdat's Avatar
Default Ls vtec Knock Sensor problem...
i have a ls vtec 94 integra with a b16 head.. i'm using a 94 gsr stock ecu.. and as you guys know it looks for the knock sensor... i recently bought a knock sensor.. but it didn't came with a plug or anything.. i don't know how to hook it up to my ecu... i know that i belongs to d3 on the ecu.. and i tried using a simple wire and try to hook the wire to the knock and stick the other end to the ecu.. but it is still not working... i was wondering with anybody with expierience help me with this problem... thank you..
Old Jul 14, 2004 | 07:39 PM
Racer_209's Avatar
Default Re: Ls vtec Knock Sensor problem... (rusureboutdat)
run with the civic ecu it has no knock sensor vtec will work fine but make sure its a chip ecu 92-95 ecu civic ex or si.
Old Jul 18, 2004 | 01:09 PM
Default Re: Ls vtec Knock Sensor problem... (Racer_209)
would anybody know if i can just install the knock sensor and just leave it out...
Old Jul 22, 2004 | 09:32 AM
Phatch99's Avatar
bump... cause i need to know this too.... same problem.... help me and this guy out.
Old Jul 28, 2004 | 10:02 PM
teamols's Avatar
Default Re: Ls vtec Knock Sensor problem... (Phatch99)
some gsr's have two knock sensor run the sensor to pin d3@ecu. or you will definetly get a code23 and no vtec
Old Jul 28, 2004 | 10:42 PM
PHiZ's Avatar
Default Re: Ls vtec Knock Sensor problem... (teamols)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamols &raquo;</TD></TR><TR><TD CLASS="quote">some gsr's have two knock sensor run the sensor to pin d3@ecu. or you will definetly get a code23 and no vtec</TD></TR></TABLE>
I have never heard of that.
If you are running a wire to the ecu, you need to crimp a pin onto it, and install it into the harness appropriatly. No, you can not just leave the KS hanging. Do a search I beleive some ppl install it into the alternator bracket...
-PHiZ
huckaboo
Dec 4, 2009 10:34 AM
1.5boosted
Dec 14, 2007 01:45 PM
ys1civic
Aug 13, 2006 07:39 PM
Big Dick Bandit
Sep 28, 2003 04:54 PM
