tach installed but not detecting rpm.. why??
Old Jul 13, 2004 | 07:06 PM
ironchef25's Avatar
Default tach installed but not detecting rpm.. why??
ok this thing is pissing me off. light works. ground ok.. power ok.. but its not detecting anything... tapped the b15 on ecu..(also known as blue wire from disb) still nothing. all wires behind are cut for 4cl motor.. what am i doing wrong.. light goes on when i start the car...
Old Jul 13, 2004 | 07:09 PM
hatchinprogress's Avatar
Default Re: tach installed but not detecting rpm.. why?? (ironchef25)
is your dizzy or ignition messed up? my friends msd ign. messed up and the lite would turn on/off alot even when parked then he hooked up his stock ign. after the msd went out and the lite now works
Old Jul 13, 2004 | 07:11 PM
ironchef25's Avatar
Default Re: tach installed but not detecting rpm.. why?? (hatchinprogress)
not at all..dizzy seems fine. no check engine light.. car runs like a dream..
Old Jul 13, 2004 | 07:22 PM
damn i thought it would help but if your sure but to tell you the truth my friend didnt know till it went to the dyno.
Old Jul 13, 2004 | 08:24 PM
DXDOHCVTEC's Avatar
Did you connect it to the blue wire in the dash?
If that didnt work connect it to the negative coil wire.
Old Jul 13, 2004 | 08:27 PM
ironchef25's Avatar
Default Re: (DXDOHCVTEC)
ok.. never mind.. got it working... hhhehheheeh
the other end of the wire wasnt hooked to the tach.. hahahhahah stupid me.. hahahahahahah
bertsb18hatch
Apr 19, 2008 08:14 AM
ExplicitSpeed360
Dec 8, 2005 08:15 AM
LoseRPunKx182
Jun 8, 2005 10:22 PM
91hatchcivic
Aug 1, 2002 11:39 PM
