Cometic Head gasket question
Old Jul 13, 2004 | 05:22 PM
Pitcrew's Avatar
Default Cometic Head gasket question
Installed B16 head on 01 GSR. Can I use just the bottom layer or the new Cometic head gasket or should I use all 3 that came assembled as one? After calculating the CR with the new combination, I came up with 9.9 CR. If I had used the original head gasket the compression would have been lower. (So the formula says) BTW, its a JDM motor.
drmix
May 22, 2008 06:20 PM
msmithgsr2131
Feb 13, 2005 10:14 PM
mini-cRx
Feb 15, 2002 07:15 PM
