ECU problems anyone (greddy kit owners)?
Old Nov 22, 2001 | 04:30 PM
HiGhCaM's Avatar
Default ECU problems anyone (greddy kit owners)?
Is anyone with the greddy kit on a Si having any problems with check engine codes?
Old Nov 22, 2001 | 05:22 PM
PyroVTEC's Avatar
New User
Default Re: ECU problems anyone (greddy kit owners)? (HiGhCaM)
I have one on my EX and had CEL issues (cyl #3 misfire) when boosting over 8psi...
Old Nov 22, 2001 | 05:38 PM
FBP Si 2000's Avatar
What are the CEL codes that you are getting?
Old Nov 22, 2001 | 05:40 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: ECU problems anyone (FBP Si 2000)
Can't you get a MAP Bypass valve?
Old Nov 22, 2001 | 05:46 PM
HiGhCaM's Avatar
13,14,71,72,73,74 Ive gone over the install and its perfect I,ve done 5 or 6 or so kits. Everything points to bad ecu but I was just courious?
Old Nov 22, 2001 | 05:58 PM
Default Re: ECU problems anyone (HiGhCaM)
Are you using the "blue box" GReddy provides?
Old Nov 22, 2001 | 08:20 PM
HiGhCaM's Avatar
of course. Install on it has been checked. I havent called greddy yet and I also have a local Honda Dealer that is very help full. I was woundering if anyone else was having the same symptoms. ? Any Ideas. The first problem I was having was code 14 IAC. I replaced it but the problems still are present. Runnig Factory plugs gapped down and they seem fine.
Mykizism
Sep 1, 2004 01:18 PM
sd_ep3
Aug 7, 2004 09:00 AM
98dxhatch
Sep 10, 2003 12:10 PM
