indigo guage install this one is a tricky one
ok everyone 1st off i did search but no luck. here is my problem i have an ef and i wanna do an integra cluster swap so bought a cluter with indiglo gauges all ready installed with clear piece glued back on so i need to know if anyone can give me any info on the glow gauges im not askin about the swap, but if you have info on that it would be great also. thanks
how can i hook up the glow gauges that are wired up to a teg cluster(90-93) to my ef??? sorry if that didnt make since
it aint the cluster that im talkin about, i need to know how to hook up the glow gauges that are on the teg cluster to my ef
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote">ok everyone 1st off i did search but no luck. here is my problem i have an ef and i wanna do an integra cluster swap so bought a cluter with indiglo gauges all ready installed with clear piece glued back on so i need to know if anyone can give me any info on the glow gauges im not askin about the swap, but if you have info on that it would be great also. thanks</TD></TR></TABLE>
you'll need to use a multimeter to test where the illumination wire is. Goto that with a fuse of course. You should also notice that there is a small transformer box that you'll need to illuminate the gauges. lemme know if you have that btw, heres a vid of my teg cluster in my car
http://www.we-todd-did-racing....DE%3D
its a night vid, sorry.
hey wagon im still waitin for your vid to load but it does have the box to change colors and dimmer
I have pics @ yahoo but you have to be a member, lemme look for the links. the box that changes color is the tranformer box. Siply supply it +12v and a ground and its good to go. In fact a 9volt battery should be able to push it as a test
