98 b18c1 into 97 dx..... help
started swap a few days ago. old motors out, new motors in, shifters hooked up. there are some plugs in the wiring harness that do not match up with the ones on the new motor. I'm sure this is common so i need a link to a site that explains step by step the wiring complications. also I understand there are some wires i must add to the car i need instructions on those as well.
http://technet.ff-squad.com/
some of the sensors have to be swapped from the gsr harness onto the d series harness...and then theres some other things that need to be extended and added
fix CKP
fix IACV
add IAB
add VTEC
everything is on the link above
fix CKP
fix IACV
add IAB
add VTEC
justink4
Jul 21, 2010 06:19 PM
