Ordering Techedge wideband DIY kit- what parts do i need to click???? HELP!!!
im ordering a techedge DIY kit from the techedge site. i emailed the tech guy several times to ask what cable kit i need to order if i get a BOSCH LSU4 sensor. There is a Techedge LSU sensor and a VW LSU sensor. I found BOSCH LSU4 sensors on ebay.
here is the link to the order page and then just click on the button under ORDER NOW.
http://wbo2.com/order.htm
Go to the yellow highlighted section under "2AO Do-It-Yourself Kit
1. Do i get the 2.6m cable DIY kit for $194, or 4.0m cable DIY kit for $199?
2. Do i get the 6 066 or 7 057 harness connector kit?
This is what the tech guy said i need to order, Is this right?
"This is what you need to get as well as getting your own 7057 sensor for
US$35 delivered from 1st VW parts :
With display
1 $9 6 pin 7 057 connector kit $9.00
1 $194 Wideband 2A0 kit (with 2.6 cable kit) $194.00
1 $70 TE-LD01 LED Display kit $70.00
Total of above goods = $273.00 -- Total of insurance $11.00
Weight for posting = 820 grams -- Total of postage $24.00
Total of order in Australian dollars AU$308.00
AU$308.00 ~= US$225"
Thanks for any info----because i need it
With display
