Honda S2000 Honda S2000
What do you guys use?
Old Jul 13, 2004 | 03:09 PM
DudeRick's Avatar
Default What do you guys use?
In your S2000, Synthetic or regular oil?
Old Jul 13, 2004 | 03:22 PM
SKRacer's Avatar
Default Re: What do you guys use? (DudeRick)
I only use synthetic during the summer.
Old Jul 13, 2004 | 06:07 PM
papa5murf's Avatar
synthetic
Old Jul 13, 2004 | 06:28 PM
Nishant's Avatar
Default Re: What do you guys use? (03s2kblue)
mobil 1 synthetic
Old Jul 13, 2004 | 07:32 PM
TougeFighter's Avatar
Default Re: What do you guys use? (swtxaznrac3r)
Ditto^
Old Jul 13, 2004 | 07:36 PM
profpin's Avatar
Default Re: What do you guys use? (TougeFighter)
royal purple synthetic...
Old Jul 13, 2004 | 07:40 PM
speed4tu's Avatar
I use amsoil syn 10w-30
Old Jul 15, 2004 | 10:58 AM
evil vapor's Avatar
Default Re: (speed4tu)
redline
Old Jul 15, 2004 | 01:55 PM
Project SSAP1's Avatar
mobil 1...so far so good...
Old Jul 15, 2004 | 02:10 PM
TXS2K's Avatar
Default Re: What do you guys use? (Validity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Validity &raquo;</TD></TR><TR><TD CLASS="quote">I only use synthetic during the summer.</TD></TR></TABLE>
Is it ok to switch back and forth between synthetic and regular?
Old Jul 17, 2004 | 11:55 AM
Steve-'s Avatar
Default Re: What do you guys use? (TXS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TXS2K &raquo;</TD></TR><TR><TD CLASS="quote">
Is it ok to switch back and forth between synthetic and regular?</TD></TR></TABLE>
NO it's not good to switch it wears the engine down really bad
we use synthetic
Old Jul 17, 2004 | 02:00 PM
CBRF4i's Avatar
Its ok to switch back and forth. it wont wear your engine bad. Why would 2 different oils wear down your engine. In the end regular and synthetic are the same thing except for a few additives in synthetic. It wont hurt to go back and forth.
Old Jul 17, 2004 | 04:06 PM
OC 335i's Avatar
Default Re: (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">redline </TD></TR></TABLE>
Old Jul 17, 2004 | 06:08 PM
JonV3's Avatar
Default Re: (CBRF4i)
I dont know but we have two good points here, does anyone know for sure cuz I can see in both comments. Is switching from synthetic to regular bad. I only use synthetic and I dont switch back, and I wouldnt put anything esle so I guess it doesnt matter but I would like to know.
Old Jul 17, 2004 | 06:18 PM
TXS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBRF4i &raquo;</TD></TR><TR><TD CLASS="quote">Its ok to switch back and forth. it wont wear your engine bad. Why would 2 different oils wear down your engine. In the end regular and synthetic are the same thing except for a few additives in synthetic. It wont hurt to go back and forth.</TD></TR></TABLE>
Sorry but you are way off base, regular oil and synthetic are nothing alike...do your research before answering a question blindly. That makes you look like you don't know what you are talking about.
http://www.mobil1.com/index.jsp
Now does anyone know for sure if it hurts? I've heard that it's not good for the engine, but I've never seen factual data saying so...thanks for any help
Old Jul 18, 2004 | 09:04 PM
neo1z's Avatar
Default Re: (TXS2K)
Ive been using a blend (Durablend actually) - is this acceptable...I am changing it every 3k so I really dont feel like I am shortchanging myself that much. Or is it not really an issue of mileage - is synthetic simply superior to a blend?
Enlighten me.
Old Jul 20, 2004 | 08:18 AM
evil vapor's Avatar
Default Re: (neo1z)
whoever in here that says switching from syn to regular oils is bad clearly has no idea what they are talking about. I can't believe that is going around.
Syn oils are formulated to last longer, ie increase oil change intervals. So changing your oil earlier is wasting $$$, oil, and time.
Engine oil has come a long way since the past, most of the stuff you find on the shelf will be adequete to use and unless you're splitting hairs, there's nothing to worry about. The only thing that should be worried about is the level of oil in your cars, not too much, not too little.
Bulli Kid
41
Aug 24, 2007 06:36 PM
HELLAnorcal
Jul 1, 2007 08:50 PM
DudeRick
Honda S2000
Jul 12, 2004 08:46 PM
nbintegracing00
May 2, 2004 05:50 AM
Brian-Brian
Sep 25, 2003 12:34 AM
