why does my shift light stay on?
Old Jul 13, 2004 | 02:39 PM
kaoss_11's Avatar
B A N N E D
Default why does my shift light stay on?
I did everything right. b16 in 91 hatch. The only thing i did different was that instead of spilicing the dizzy wire i puit the wire in between that yellw cap thing right after the dizzy.
Modified by kaoss_11 at 6:33 PM 7/13/2004
Old Jul 13, 2004 | 02:40 PM
gac_gonejeepin's Avatar
Default Re: why does my shirt light stay on? (kaoss_11)
what?!
your what light?!
--gabriel
Old Jul 13, 2004 | 02:44 PM
beavis's Avatar
your seat belt light?
Old Jul 13, 2004 | 03:21 PM
EL Vap133's Avatar
Shirt light? LOL?
Old Jul 13, 2004 | 03:41 PM
90dxhatch's Avatar
Default Re: why does my shirt light stay on? (EL Vap133)
lol get some girls in the car and see if them taking there tops helps at all.
-joe
Old Jul 13, 2004 | 03:42 PM
mr. carpenter's Avatar
Default Re: why does my shirt light stay on? (90dxhatch)
because some shirts are hardwired to stay on.
Old Jul 13, 2004 | 03:49 PM
LAMA's Avatar
Default Re: why does my shirt light stay on? (mr. carpenter)
Old Jul 13, 2004 | 05:33 PM
kaoss_11's Avatar
B A N N E D
Default Re: why does my shift light stay on? (kaoss_11)
bump
Old Jul 13, 2004 | 05:46 PM
Origin's Avatar
did you mean shift light? do you have an hf? or did you install a big tach with the shift light? if it is shirt light can you explain where that is?
Old Jul 13, 2004 | 05:49 PM
kaoss_11's Avatar
B A N N E D
Default Re: why does my shift light stay on? (Origin)
yes i installed a big tach with a shift light and it stays on
Old Jul 13, 2004 | 05:53 PM
LAMA's Avatar
oh, I thought you meant shirt light.
Old Jul 13, 2004 | 05:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote">yes i installed a big tach with a shift light and it stays on</TD></TR></TABLE>
it all makes sense now. you know we were just messing with you. i would go back over your wiring just to be sure. if that's not it, i'd see if you can exchange it. did you get it local or on line?
Old Jul 13, 2004 | 05:59 PM
kaoss_11's Avatar
B A N N E D
Default Re: why does my shift light stay on? (mr. carpenter)
Off a friend. It even stays on when the car is totally off.
Old Jul 13, 2004 | 06:04 PM
weird. it's direct wired to the battery probably? how did you wire power to it?
Old Jul 13, 2004 | 06:06 PM
kaoss_11's Avatar
B A N N E D
under the dash board. Hooked it up to the radio, clock, and etc fuse. Thats correct isnt it.
Old Jul 13, 2004 | 06:08 PM
LAMA's Avatar
i dont think so, because you can have the clock runing when the car is off correct?
Old Jul 13, 2004 | 06:09 PM
no there is constant power to the clock in order to maintain time while the car is off. search shift light or a/m tach or try to find something that only comes on while the car is on. ask your friend how he had it wired. i found this thread.
https://honda-tech.com/zerothread?id=784792
Old Jul 13, 2004 | 06:12 PM
kaoss_11's Avatar
B A N N E D
I already asked and it was in his 93 gsr. The light never worked for him. So basically it sounds like the power source i am using isnt a good one because it is always on correct.
Old Jul 13, 2004 | 06:15 PM
this thread tells which one to use from the guage cluster.
Old Jul 13, 2004 | 06:17 PM
kaoss_11's Avatar
B A N N E D
I have no rpm gauge.
Old Jul 13, 2004 | 06:23 PM
i'm not positive but i would check in the cluster. even though you don't have the guage i think the wiring is still there. i know that when you swap a cluster that has no tach for on with a tach, the tach works without adding wires providing you stay year specific. i put an 89 cluster with a tach into my 91 and it worked fine. i had to do some rewiring but i had a tach wire. i'll see if i can find the pinouts for the harness. what year is the car?
Old Jul 13, 2004 | 06:36 PM
look in this link. there are pics showing the pinouts and which one is the tach. i think it was #8blue wire on the b harness.
http://www.ef-honda.com/main/viewtopic.php?t=1400
Old Jul 13, 2004 | 08:04 PM
USDM 4G VTEC's Avatar
people here act so surprised'
seems they dont know the HF CRX's has a upshift light arrow
Old Jul 13, 2004 | 08:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote">. b16 in 91 hatch. Modified by kaoss_11 at 6:33 PM 7/13/2004</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">people here act so surprised'
seems they dont know the HF CRX's has a upshift light arrow</TD></TR></TABLE>
where did you get hf crx?
Old Jul 13, 2004 | 09:40 PM
90dxhatch's Avatar
use a multi meter to test the wire you used you might have the signal wire off the tach ran to 12v or just maybe a bad ground. did you try adjusting the shift light rmp range, maybe it's set to come on at 0rmps?
-joe
