What AC compressor/bracket do I use for a B18B into 97 Civic EX swap? dfw / dallas
Old Jul 13, 2004 | 01:35 PM
Edwardo911's Avatar
Default What AC compressor/bracket do I use for a B18B into 97 Civic EX swap? dfw / dallas
I blew the compressor that was on my stock d16y8 engine. I am having a B18B put in, but need to retain my AC-hot as hell here in Texas in the summer time. I read that I need the stock compressor, but my mechanic says I need the mounting bracket off a 94-97 Del Sol with a stock b16 engine. Just want to check on this.
-Edward
PS-Anyone have these parts for sale in/around dfw?
Old Jul 13, 2004 | 02:23 PM
2000DX's Avatar
Default Re: What AC compressor/bracket do I use for a B18B into 97 Civic EX swap? dfw / dallas (Edwardo911
You need the p54 a/c bracket off an 94-95 Del Sol VTEC. The part number is 38930-P54-000.
Old Jul 13, 2004 | 02:32 PM
B18_Civic's Avatar
you dont have to get a new bracket. i had a 95 b18b put into my 96 civic. but the only thing is that only two bolts fit. myself i live in dfw as well but i just took off the belt.
Old Jul 13, 2004 | 02:34 PM
2000DX's Avatar
Default Re: (B18_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18_Civic &raquo;</TD></TR><TR><TD CLASS="quote">you dont have to get a new bracket. i had a 95 b18b put into my 96 civic. but the only thing is that only two bolts fit. myself i live in dfw as well but i just took off the belt.</TD></TR></TABLE>
He said he needs to retain his A/C.
Old Jul 14, 2004 | 04:17 AM
Edwardo911's Avatar
Cool, Thanks for the part number. But which compressor do I use?
-Edward
Old Jul 14, 2004 | 07:37 AM
jinu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edwardo911 &raquo;</TD></TR><TR><TD CLASS="quote">Cool, Thanks for the part number. But which compressor do I use?
-Edward</TD></TR></TABLE>
Use the Civic's compressor and the Del Sol's bracket
Old Jul 14, 2004 | 09:47 AM
LOSERboy's Avatar
you can also use the jdm a/c bracket. If you have a b-series swap you can utilize this bracket with any civic a/c compressor.....its aluminum and weighs about 2 lbs. but its kinda pricey.....@ jdmhondaparts.com it costs about $120.00
Old Jul 14, 2004 | 01:41 PM
B18_Civic's Avatar
Default Re: (2000DX)
like i said you can with the stock bracket. but i took my belt off.
Old Jul 14, 2004 | 01:47 PM
Mighty's Avatar
Since your Civics compressor is bad you might be better off using the Integra compressor and bracket. Im not sure the lines will match up but I think they will. Try searching for info on Integra compressors in Civic.
Old Jul 14, 2004 | 01:59 PM
DavidR's Avatar
I think the Del Sol bracket is backordered right now, but the CRV isn't. CRV works too.
siblue_gzer
10
Jun 14, 2006 10:52 PM
HatchbackSqueegee
Jun 29, 2005 07:16 AM
honda20
Jun 8, 2005 03:39 PM
honda20
May 26, 2005 08:23 PM
haloseven
16
Aug 19, 2001 11:36 AM
