B18A CRX
Old Jul 13, 2004 | 01:22 PM
allmotorlsvtecrx's Avatar
Default B18A CRX
MY CRX IS HARD TO GET STARTED BUT WHEN IT GETS WARMED UP IT WILL STAY RUNNING BUT HAS AN IRATIC IDLE.
ALSO WHEN I TRY TO KEEP A STEADY SPEED ABOVE 65MPH IT STARTS TO CUTOUT. CAN ANYBODY HELP ME!!!!
Old Jul 13, 2004 | 01:26 PM
4drEF's Avatar
Keyboard Humorist
Default Re: B18A CRX (skyt321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skyt321 &raquo;</TD></TR><TR><TD CLASS="quote">CAN ANYBODY HELP ME!!!!</TD></TR></TABLE>
I doubt it.
Old Jul 14, 2004 | 01:08 PM
1.888's Avatar
CLOGGED CAT?
THROWING ANY ERROR CODES?
Old Jul 14, 2004 | 01:09 PM
EL Vap133's Avatar
What's up with the caps today?
Old Jul 14, 2004 | 01:11 PM
APEX CRX's Avatar
Default Re: B18A CRX (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">What's up with the caps today?</TD></TR></TABLE>
yeah TAKE THE CAPS OFF!!
Old Jul 14, 2004 | 01:23 PM
Jester88Si's Avatar
Dude that means your engine is no good and is about to blow better get rid of it and buy another!
Old Jul 14, 2004 | 02:14 PM
ServiceAdvisor's Avatar
We need more info to fully respond to your post skyt321.
Car:?
Make:?
Model:?
Engine:?
ECU Code(s):?
Problem summary:?
Events leading up to problem:?
Old Jul 17, 2004 | 10:29 AM
Default Re: (OldSiHatch)
I have an 88 crx si with a b18a in it. The only code it is throwing is the engine coolant sensor(code 6). First it is hard to get started in the morning or if it sits to long but even when i get it running it still has an erratic idle. and when i try to hold a stedy speed at anything above 65 mph it cuts out. could all of my troubles be from that sensor. i have tryed everything i know. help!
Old Jul 17, 2004 | 11:03 AM
erebunicrx's Avatar
Default Re: (skyt321)
what kind of ecu are you using?
Old Jul 18, 2004 | 10:25 AM
Default Re: (erebunicrx)
I have a Pr4 with mugen chip.
Old Jul 18, 2004 | 04:37 PM
01-0720's Avatar
Pull the dist. cap off and see if the rotor is loose because ls motors
are known for that.
Old Jul 18, 2004 | 04:49 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: B18A CRX (01-0720)
Yea definately check the rotor to see if its loose...also check for any moisture inside the cap. While youre at it go ahead and check the plugs/wires. That coolant sensor could hurt your initial startup if its bad and the motor is going directly into open loop. Prolly not though. Does it idle shitty/low until its warm or does it always idle shitty?
Sean
Old Jul 20, 2004 | 09:53 AM
Default Re: B18A CRX (sCeRaXn)
it always idles shity.
Old Jul 20, 2004 | 11:14 AM
Dyn0speed's Avatar
well the ect sensor will effect cold starting. check your IAC try pulling off the iac connector while idling and you should see a big idling different(idle much higher with it off), if there is no different then its probably it. ECT is one of the primary sensor tat the ecu will look at during open loop.
Old Jul 20, 2004 | 11:51 AM
Default Re: B18A CRX (Dyn0speed)
what is the ect sensor and were is it located on the car my car.
Old Jul 20, 2004 | 11:53 AM
5litereater's Avatar
i have a crx hf with a b18a1 and my irractic idle is coming from my timing being off. check and double check cam and iginition timing. check your main sensors (TPS, IACV, etc).
Old Jul 24, 2004 | 04:25 PM
Dyn0speed's Avatar
engine coolant temperature sensor and its located under the distributor....
Old Jul 24, 2004 | 05:35 PM
temp's Avatar
my suggestion is get rid of the shitty ECU and get a STOCK PR4 ecu
riyakhan
26
Sep 18, 2007 07:45 AM
CSM Motorsports
Sep 26, 2006 04:33 AM
andrey320
Jun 7, 2006 02:12 PM
sanman00
Nov 7, 2005 04:07 PM
FURACERMAN
Oct 4, 2004 05:58 PM
